Thread: LMF 314mm Brake Upgrade...
    Stoke on Trent
    Default LMF 314mm Brake Upgrade...
    LMF are doing a 314mm brake upgrade. Will these fit my LS with aftermarket 17" wheels ok? And will i notice much difference?
    They are £319.00, i take it this is for a set of 4 is it?
    There is an option for drilled or grooved, which are better?
    Also what pads should i get?
    The ones they are selling are Red Stuff pads.
    Sorry so many questions, and thanks in advance.
    Gaz.
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    the brake kit is fopr the fronts only.
    people who have had this kit fitted have been ravin about the difference.
    not sure about the fittin behind ure wheels or anything else, someone will be along shortly
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Vectra elite
    Engine : 1800
    Mileage : 80000
    will fit 17`s as its the set up the newer vectra /signum ones have
    Stoke on Trent
    is it much better? or is it worth investing in brembos or something similar?
    member of the smoke patrol 230bhp+
    good news for you iv got them under a set of 16ins alloy wheels
    Stoke on Trent
    are they any good mate? did you notice any difference?
    Gaz
    Quote Originally Posted by vauxhall4life View Post
    Gaz
    you will find a big difference in your braking
    Stoke on Trent
    okay thanks, have you got the drilled or grooved? or neither?
    drilled for cooling ,,i use drilled
    grooved for stopping
    Stoke on Trent
    ah rite okay. cheers.
  1. For Sale: 314mm brake upgrade
    By Craig1985 in forum Parts for sale
    Last Post: 3rd May 2012, 15:11
  2. 314mm brake upgrade
    By peteopc in forum Suspension, Wheels & Brakes
    Last Post: 23rd August 2009, 11:43
  3. GSi Brake upgrade to 314mm?
    By fuzzbomUK in forum Handling & Braking
    Last Post: 16th September 2008, 12:57
  4. 314mm brake upgrade
    By steve1975l in forum Suspension, Wheels & Brakes
    Last Post: 30th June 2008, 21:12
  5. 314mm brake upgrade
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 14:23
