Results 1 to 10 of 16
Thread: fitting Eibach springs...
    Redhill
    Default fitting Eibach springs...
    Hi Guys... i so need my car lowered, so sick of the "what seams 4" gap" between the tire and wheel arch...
    going to go for the Eibach -30mm springs.. what these like to fit.. i have done springs and shocks on a vec b before, but never even had the wheels off my vec c.. anyone done this, any tips or advice welcome..
    cheer Mark
    oh mine's a 56 plate facelift Sri 1.9 cdti 150, if this makes any difference
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    If you can do them on a B you have no probs,only thing is as you've a sri the springs will only drop it 15mm as the suspension is 15mm lower as standard on the sri.
    Redhill
    as long as it hardens up the ride and drops the front a bit i'm cool with that...
    Cirencester
    go for GMAX or Pi springs mate. both drop 45F and 40R
    Stoke on Trent
    Sorry to jump in here but ive got a vectra LS on 17" alloys and want it lowering, not sure if 30mm will be enough though?
    If i go more i believe i need to fit uprated shocks dont i? Is it best to do this anyway? Can anyone reccomend a good lowering kit? Springs and Shocks?
    PS. I dont want it stupidly low, 80mm etc, lol. Just to take up the gap and improve handling.
    Gaz
    Sunny Dartmoor
    Go for the PI springs,that'll lower your LS 40-45mm,no need to upgrade shocks,best bet imo mate.....
    Stoke on Trent
    This is going to sound like a right newbies question, lol, but are shocks and dampers the same thing?
    Also will i need to alter my camber?
    Thanks alot.
    Sunny Dartmoor
    Quote Originally Posted by vauxhall4life View Post
    Thanks alot.
    Yes they are mate,would definately get a wheel alignment check done on the safe side,most place's dont charge if they dont have to adjust anything.......
    Stoke on Trent
    Okay thanks very much. Just found them springs on 'motor sport world'. Only £107.00, it says they lower the rear 40mm and the front 45mm. Wont this look a bit odd? Lol.
    Gaz
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Nope,most vecs look nose high so a split drop evens the height out.
  1. Fitting Rear Eibach Springs
    By 798EAT in forum Handling & Braking
    Last Post: 10th July 2011, 14:52
  2. Eibach fitting before and after(pre-settling)
    By Carmaduk in forum Handling & Braking
    Last Post: 3rd June 2011, 15:38
  3. fitting eibach springs
    By Mads in forum Suspension, Wheels & Brakes
    Last Post: 13th April 2011, 01:15
  4. Eibach Springs plus......
    By MattW in forum Handling & Braking
    Last Post: 12th February 2009, 20:20
  5. Eibach Pro - Springs
    By pjjohnst in forum Handling & Braking
    Last Post: 21st January 2009, 20:58
