Thread: Drivers side mirror
    Jan 2006
    Cardiff
    Default Drivers side mirror
    Here is a picture of an anti dazzle drivers mirror are the wires correct, as the wires on my mirror are white / grey & yellow if it were plugged in would it work. Have the dimming inside mirror.
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Aren't the wires you mention just for the electric mirror motor? Should you not have two plugs/connectors and two extra wires for the heating element?
    Jan 2006
    Cardiff
    No the extra wires to the left are for the anti dazzle part, they don't seem to match the wires in the mirror housing, I've upgraded to the electric folding mirrors with the anti dazzle so just wanted to know if these are compatible with the wiring in mine.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Sorry for the dumb question, where are the wires for the heating element??
    How is this anti dazzle controlled? Is it from the interior self dimming mirror?
    @home
    Engine : 1.9 CDTi
    Quote Originally Posted by Steve-E View Post
    Sorry, I meant the wire in your mirror. How many connectors do you have inside the mirror casing and do you have the auto dim mirror connected via a VX harness?
    Jan 2006
    Cardiff
    Here is a pic of the wires in the housing the heater wires are connected the motor plug is connected the spare plug that you see should be for the anti dazzle mirror connection, but the wires on the mirror do not match,
    @home
    Engine : 1.9 CDTi
    I wouldn't worry about the wires not matching, the plug can only go one way. Is your anti-dazzle mirror wired into the ribbon cable or have you wired it up yourself?
    Jan 2006
    Cardiff
    Wired into the ribbon cable.
    @home
    Engine : 1.9 CDTi
    knowing vx, it may need a tech2?
  1. Drivers side mirror has fallen out
    By pipamish in forum Bodywork & Interior
    Last Post: 10th July 2012, 19:00
