Thread: intermitant rev and speedo
    midsomer norton,bath
    Default intermitant rev and speedo
    hi again!!!
    help needed please!!....i have my r reg sri vectra and the speedo and rev counter is playing up,sometimes its fine and all work fine,however sometimes i will get in and turn key to II possision and the rev needle will flicker and when started the speedo doesnt work and rev needle still slightly flickering.....water temp and fuel all working as normal and dash lights still work????
    please help and is starting to annoy!!!!!!!! thanks guys!!
    Regular Member jack's Avatar
    slaming doors since 1976
    have you had your whole display unit checked via tech2? or anything checked on it?
    no not yet, some1 mentioned the ABS sensor before to me??....does this ring any bells????
    could it be a faulty conection at back of dials u think???....if i go out in the car first thing in the morning it works fine,then drive it again shortly afer it plays up....if i leave the car for a few hours then its ok again?????
    ye sounds like a faulty connection in the unit itself id say as the are cealled up id have a check on it get them to check all the dials and instruments work i wouldnt have said abs all your lights work in the display ok?
    yea ALL lights workin fine so i will take the dials out qand clean up connections on the back and see if that works!!#
    thanks 4 ur help...good man!!
  1. intermitant wiper
    By Kaikianjames in forum Electrical & ICE (including SatNav)
    Last Post: 4th January 2013, 21:25
  2. Intermitant ecu light on
    By sriandy in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2012, 23:33
  3. intermitant power loss
    By Dougb in forum Engine & Drivetrain
    Last Post: 1st July 2010, 11:07
  4. intermitant starting problems
    By pward in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2010, 21:05
  5. Intermitant Dial Failure
    By ballogie in forum Electrical & ICE (including SatNav)
    Last Post: 23rd August 2007, 12:21
