Results 1 to 2 of 2
Thread: Cable through bulkhead
    VIP-Member paulmac's Avatar
    Slough
    9 Post(s)
    Default Cable through bulkhead
    Does anybody know how to run a cable from the engine bay into the cabin going through the bulkhead?
    Car is Vectra 3.2 Gsi 04 Manual.
    Thanks in advance.
    Paul
    Jul 2006
    There's a grommet in the bulkhead.
    Open the bonnet, lift the scuttle panel (under the wipers) on the passenger side, and you should be able to see the grommet. Feed the cable through there, then to get at it inside the car you'll have to take out the glove box (5 torx screws).
    I did a How2 for an amp & sub install, there's some pics there if you have a look.
    HTH
  1. Water leak from bulkhead??
    By dap1977 in forum Engine & Drivetrain
    Last Post: 9th October 2011, 11:02
  2. Heater Pipes (?) into Bulkhead
    By fifesri in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2011, 21:58
  3. easiest way throug bulkhead?
    By opel_estate in forum Electrical & ICE (including SatNav)
    Last Post: 22nd April 2011, 10:41
  4. Bulkhead
    By Fingershot1 in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2009, 21:20
vectra c how to get a cable onto the cabin
running a cable through a vectra c
