Thread: rear top arms. how to change.
    Regular Member kev bux's Avatar
    Jan 2006
    BOROUGHPETER
    Default rear top arms. how to change.
    as above, any tips on how to change them?
    any help appreciated.
    are the ones off ebay any good or is it better to buy them off lmf?
    thanks.
    kev.
    West
    Personally i think you are best using genuine parts, ive heard the cheap option doesn't last too long.
    btw how much are they on ebay?
    Jan 2006
    BOROUGHPETER
    on ebay they are about £32 each. postage included in this price but dont know if the postage covers 2 items.
    Regular Member NI-2.2SRI's Avatar
    Northern Ireland
    i bought 2 outa my local motor factors, no problems so far, been n bout 5 months nw. jus 2 bolts on each arm, pretty easy to change mate, just wee bit awkward to remove the inner bolts. think i used a couple of extension bars an a nuckle joint. the only other thing is to remover the wire that runs along the arm, the clips jus pull out an push back in.
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    i bought one off ebay last year, no problems with it.
    pretty simple to change to.
    i found takin the rear spring out helps alot. then its just 2 bolts, one either end of the arm
    Jan 2006
    BOROUGHPETER
    cheers lads, dont know if i need em yet but i just wanted to know for future reference.
    sorry to disagree with Carl.. but there's no need to take the spring out...it doesn't help ( but carl is on coilovers) ...it's just two bolts and the inner one is a pig to get at...
    i just found removin the rear spring on mine made it easier to get a couple of spanners in for the inside bolts.
    im not sure how different the coilover spring is to the standard lowering spring.
    edit: i think the other reason i removed the rear spring was cus it was real easy, a bit of force and i could squeeze the spring off with me hands, due the to springs bein quite short.
  1. Best place to get rear trailing arms/banana arms??
    By paz_badboy4life in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2012, 09:53
  2. Rear boomerang arms
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2011, 20:41
  3. Rear Arms
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2011, 20:14
  4. Different Rear Control Arms?
    By ChrisBilly in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2010, 15:26
  5. Advice needed - How to change vectra c rear suspension arms
    By OSSY in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2010, 12:06
