Results 1 to 10 of 11
Thread: Swirl Problem?!?!
    Jan 2008
    Scunthorpe
    Default Swirl Problem?!?!
    Sounds like ive got the swirl valve problem?! only had the car (04 sri cdti 150) 3 weeks, and at low revs under 2000 rpm its very very very very very slow to accelerate until the turbo kicks in. it only does it now and again not everytime. any ideas ?? its still under warrenty by perrys for a year but would this be covered?? thanks for your time
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Have a quick peek at this thread & then pop your engine cover off & visually inspect >>
    Any check engine/Dash lights illuminated ??
    Dean
    Jan 2008
    Scunthorpe
    nope no lights, not had a look at it yet, dont really know what im doing with cars specially diesels! when i ring perrys, what do i say is wrong with it? do i play dumb? and tell them the symptons only or do i mention swirl valves, 3rd injectors, inlet manifold, egr valves???
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    State your symptons and then let them diagnose the cause. You could say I've got a 'friend' whos had a similar problem and it ended up being something like the EGR or Swirl valve do you think this could be the same problem? Lets them know you know a bit about it. And yes it should be covered under warranty because both parts are not a consumable (ie meaning a regualr replacement part like diesel filter or brake pads)
    good luck
    Regular Member jack's Avatar
    slaming doors since 1976
    egr falve is a warranty replacement part if not ask why iv changed loads in the past on astra g models and theyve been covered thats a fact.
    thats by perry's by the way.
    Jan 2008
    Scunthorpe
    okies thanks
    Regular Member justyb's Avatar
    wigan
    sounds like an EGR valve is faulty m8y
    Jan 2008
    Scunthorpe
    rang perrys, going back in on thursday 28th 1.30pm, perrys vauxhall in barnsley.
    Jan 2008
    Scunthorpe
    started the car today, sounded really rough!! revved it and it wouldnt go over 2500 revs now, and kicking loads of blue smoke out the exhaust, burning oil. rang perrys to explain i cant drive the car to them on thursday, they said use my recovery i got with the warranty to get the car to them so its gone in today, hopefully hear something soon, to be honest im not impressed only had it 3 weeks! and now i find myself without a car, only upgraded to get something new and 'more reliable' its only done 24k its a joke.
  1. Potential swirl problem
    By Lito in forum Engine & Drivetrain
    Last Post: 12th August 2012, 09:36
  2. Swirl bar problem
    By nicj in forum Engine & Drivetrain
    Last Post: 23rd July 2012, 16:49
  3. Swirl flaps problem i think
    By srinav in forum Engine & Drivetrain
    Last Post: 30th July 2011, 23:41
  4. swirl actuator problem
    By ziggi in forum Engine & Drivetrain
    Last Post: 30th September 2009, 03:34
  5. Swirl Actuator Problem... or not?!
    By djr69uk in forum Engine & Drivetrain
    Last Post: 2nd May 2009, 21:18
