Results 1 to 10 of 15
Thread: Replacing rear signum springs
    Regular Member eaglepva's Avatar
    Up North
    Default Replacing rear signum springs
    Hi, Been tryin to find the how to on replacing the rear springs but cant seem to find it.
    Does anybody know the tools i need to do it myself
    Cheers.
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    You need a torx e18 socket and an 18mm spanner, jack car up and put axle stand under then lower jack and put under lower arm, then undo one bolt near the rear hub then lower jack and spring should come out if it dont you will have to bar the arm down a bit. Then just reverse the procedure to install the spring.
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    Default Replacing Rear Springs.
    It states in the manual:- Jack up car (to take pressure off rear spring), remove brake caliper and tie up out of the way (new bolts required when refitting), fit spring compressor and compress spring, remove spring and upper damper ring and lower spring stop. To refit:- replace new top and bottom pads, seat spring correctly and remove compressor. Job done (sorry replace brake caliper (new bolts) and wheels).
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    You DONT need to remove caliper or a spring compresser thats why you use the jack to release the pressure when removing then to compress it when refitting.
    Jul 2006
    TENTERDEN KENT
    As I said "it states in the manual" as I have not carried out this job myself, but thanks for the information anyway.
    Ashington, Northumberland
    Quote Originally Posted by eaglepva View Post
    Cheers.
    Or you could just bring it to me and I'll have it done in 20 minutes
    Regular Member corman's Avatar
    Mar 2007
    hexham
    which i would totally recommend
    Sep 2009
    south holland
    Quote Originally Posted by Daywalker View Post
    Sorry for digging up an old thread but have been trying to remove a rear spring (to remove the helper spring installed by PO) using this method. I assume you can remove the spring without the use of spring compressors. However I was unable to get the spring out, there was still a lot of tension on the spring. Can someone explain the "you will have to bar the arm down" part? (eg do I use a hammer or pry bar and on which part of the arm can you put pressure without damaging)
    Thanks,
    Jaap
    Leicester
    Once you have the car supported and the bottom of the damper is disconnected, you can press the suspension arm down with your foot and the spring will fall out, even with spring compressors.
    But.....................I would consider leaving them in, Signum's and Vectra's have a habit of wearing the insides of the rear tyres, spring assisters pretty much stop this from happening.
    I managed to get 28000 miles out of a rear set of 19's on my last Signum before the insides were not too clever.
    Sep 2009
    south holland
    Quote Originally Posted by Maverick View Post
    Thanks, didn't realize I also had to disconnect the damper. On my vectra tyre wear seems even although they wear in such a pattern that they start to make a lot of noise. Was thinking about getting an alignment done , so seemed like the right time to also get the helper spring out.
    Jaap
  1. replacing standard springs with Sri springs
    By mon in forum Handling & Braking
    Last Post: 31st December 2012, 22:03
  2. Signum Rear Springs
    By kwillhen in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2010, 20:26
  3. Signum v6 rear springs
    By mark230678 in forum Parts for sale
    Last Post: 26th June 2009, 22:03
vectra c rear spring removal
air spring assisters. n ireland
vectra rear spring replacement
vectra c2 rear spring replacement
vectra-c.com rear springs
vectra c rear spring replacement guide
rear road springs on a vauxhall signum
change rear springs vectra c
opel signum rear spring
