Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: remaps 888 or bsr
    grimsby
    Default remaps 888 or bsr
    i am looking at getting a remap and anyone help 888 or bsr
    cheers
    Full Member Big Sig's Avatar
    Either, BSR contact LMF. You can do it on your drive. 888, You need to go to them. Both give similar results.
    Regular Member Karl's Avatar
    Sunderland
    I think the main advantage of the BSR map is that you can load it on or remove it at any point, yourself. So if a dealer reflashes your ecu (as they seem to like to do from time to time) you just reflash with your map, instead of having to drive to 888 for it to be done.
    grimsby
    is the bsr undetectable if you remap back to original
    Here, there and every where!
    Yes m8.
    grimsby
    got my vectra 150 with a psi cr powerbox already fitted only set at 8 mid setting took it off today didnt really make that much difference
    will a remap make alot of difference and do they use much more fuel
    think with box fitted my comp tends to lie abit says it had done 49 mpg but when worked out looked more like 42mpg
    grimsby
    looks like i am starting to sway towards bsr/are they easy to use and where best price from
    cheers
    grimsby
    do they come with just one remap or do they have more to choose from
    cheers
    Regular Member mushy2007's Avatar
    Liverpool
    There is just 1 re-map, however they do three stage tuning if you really want some power.
    They are extrmely easy to use, plug and play, have a look at the video here:- http://www.bsruk.co.uk/tuning_ppc.htm
    grimsby
    Smile
    cheers mushy looks a very good bit of kit have you got 1 fitted and would you say there well worth it
  1. Remaps.....why pay more?
    By bafoo in forum Vectra C / Signum Car Chat
    Last Post: 24th October 2010, 18:02
  2. Remaps???
    By V2 5TE R in forum Diesel Engine related
    Last Post: 26th August 2010, 20:33
  3. remaps
    By paul19 in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2008, 18:55
  4. remaps
    By AndyvectraR in forum Tuning
    Last Post: 22nd August 2008, 15:42
  5. remaps
    Last Post: 16th August 2008, 19:58
