Thread: Key Battery
    Larkhall
    Default Key Battery
    I changed the battery on the key last night and went to open the car and none of the buttons worked. I had to manually open the car and get in, setting the alarm off!!
    It switched off when i put the key in the ignition and now the key works fine. I take it it just needed resetting?
    Regular Member martind511's Avatar
    Swindon
    Vehicle : Audii A3 Sportback
    Trim : S Line Black Edition
    Engine : 2.0 Diesel
    Year : 2011
    It just needed to re-learn the rolling immobiliser codes (IIRC).
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Yep im sure you have to put key in ignition and then press the lock button to reset it
    south wales
    how do you change the battery mineshard to open
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. Key fob battery
    By Fausty in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2011, 02:38
  3. Battery
    By Wolfie01 in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2011, 23:52
  4. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  5. Battery light on, 14.4V at the battery!
    By Saulty in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 23:29
