Thread: Speedo playing dead again ...
    Luton
    confused Speedo playing dead again ...
    55 reg 2.2 Signum .... after quite a few months of no problems, Wifey started the car at the local supermarket and hey presto - no speedo, tacho, fuel, or temperature read out. Previous experience (twice) is that if the car is re-started, all Instruments wake up, and no diagnostic codes are posted. Wifey knew if the engine was turned off Mr Vx Main Dealer would not see the problem so she had the presence of mind to take it in and leave the engine running .... Yes, Mrs, my those instruments are playing doggo. Twenty mintes later with Tech 2 ..... and you have guessed it - no codes posted ! Others have suggested the CIM module but Mr Main Dealer won't change it unless they get a code ....
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Think it has to it something like 25 times for a code to be stored.
    Full Member Big Sig's Avatar
    other way round. It takes 25 starts to clear a stored fault code. Could it be a loose connection? if its under warranty, they have seen the fault, leave it with them until they fix it. They cannot deny it has the fault as they have seen it! take it back!
    I think it's a lot longer than that. A stored fault code on my Elite took approx 30 days before it cleared.
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I had the same problem once so far, though I had broken it cos it was on the rolling road. Spoke to another member and they had the same aswell so it's quite common I believe.
    I'd still insist they change the CIM...that will be faulty even if it's not coding..
    Luton
    Question Update from Dealer
    Mr Dealer (Evans Halshaw) reckons there can be a similar problem with the Astra H. The cause there is that people jump in and drive off, not giving the system enough time to fully initialise from the key. Not sure I follow that .... and I did not think we did that we were `Quick Draw McGraw' with the key, but we are going to try to give the car more `wake up' time after the key has been inserted, as the problem has only happened just after drive away. Thanks for replies.
  1. been playing with my Speedo
    Last Post: 28th January 2013, 00:34
  2. No one else playing Far Cry 3 ?
    By Ian-Highlander in forum Games Room
    Last Post: 15th December 2012, 18:55
  3. dashboard dead (no rev, speedo, lights)
    By Swatty in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2011, 13:31
  4. Dead speedo and rev counter
    By omega2498 in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2007, 00:18
