Thread: Spraying a spoiler HELP URGENT
    derby
    confused Spraying a spoiler HELP URGENT
    Right just need to know how to apply the clear coat and what pressure is required. Do i apply it to wet paint or let the paint dry and then apply the clear coat. How many coats of clear laquar does it require to get that glass finish
    Jul 2006
    Let paint completely dry first - about 24 hours.
    Then apply as many coats of lacquer as it takes to look right - but NO sanding the final coat.
    Don't understand what you mean about pressure though?
    derby
    using a spay gun connected to air compressor it was originaly set to 5bar pressure when applying the clear coat i was advised to apply thick coats but was not advised at so what pressure it requires so i assume less pressure means thicker coat
    Jul 2006
    Ah, OK - out of my depth then I was assuming you were using a rattle can.
    derby
    lol rattle cans never come out right found out on my 306 W reg got thwe paint mixed and the clear laquar and guess what paint stands out a mile and its not got that glass shine to it lol so need someone that is either in that industry to give me advice or anyone that has tried it
    Regular Member EURO G's Avatar
    n ireland
    your pressure should be around 2 bar,you should leave your base coat until its dryed to a mat finish about an hour or so after last coat also leave 10 to 15 mins between coats of base,if you put to coats of clear on that should be plenty,the glass finish you talk about comes from the way you put the clearcoat on not how many coats hth
  1. spraying lip spoiler
    By vectragsi3.2 in forum Styling
    Last Post: 8th April 2010, 21:16
  2. Really need spraying advice for Lip Spoiler
    By S14RRJ in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2008, 13:38
  3. Spraying a trunk lip spoiler
    By stubopvectra in forum Styling
    Last Post: 29th March 2008, 21:28
  4. Costs For Spraying Top Spoiler
    By lillie in forum Styling
    Last Post: 5th September 2007, 22:12
  5. Spoiler spraying
    By middler31 in forum Styling
    Last Post: 26th April 2007, 19:55
