Thread: how to change glow plugs on 1.9cdti
    derby
    Default how to change glow plugs on 1.9cdti
    Quick question chaging glow plugs on 1.9cdti 2004 regeasy or hard an what tool are required and time taken to do it
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    easy m8 think its a 10mm deep socket and ratchet just be careful when taking the top connectors off that you dont snap them they squeeze then pull up as they have clips inside. time about 1 hour.. i think one at the left of the engine you need to take a tiny piece of hose from the turbo off to get socket in. HTH
    derby
    cheers mate think that will get rid of the spanner thru car symbol hopefully lol once i get it sorted iv learnt sumat in life dont get a high millage car not worth it just stick to cars with only 50000 on the clock
    Sussex
    Quote Originally Posted by mr.4dil View Post
    Sorry to ressurect a thread from the dead but just wondering if replacing the Glow Plugs resolved the spanner warning light you had. I currently have the spanner light on for about 5 minutes after starting the car from cold on my 1.9 [150] CDTi. Its going for a service but the dealer wanted an extra £110 to replace the Glow Plugs to see if this would get rid of the light. So concidering changing them myself as a set costs about £30.
    West
    Quote Originally Posted by m4tt View Post
    Plugs are aprox £13 each from the dealer & can be bought cheaper from ECP etc...
    Mine were replaced at my last service in Jan with no addition labour charge & yes if the spanner is coming on in the morning for a few mins after the first cold start, it usually the plugs at fault.
    try turning the key a few times before starting to bring the plugs on for longer & see if that helps... there's a how to for the plugs on the forum in the appropriate section...
    hth
    Feb 2011
    Had the same problem...spanner light on every morning for a few miles then went out. Glow plug replaced last week (fortunately for me under warranty). Not seen the light since. Happy days.
  1. vectra 1.9cdti glow plugs
    By killa_uk in forum Engine & Drivetrain
    Last Post: 13th May 2012, 19:50
  2. Glow plugs change
    By deeks in forum Diesel Engine related
    Last Post: 21st April 2011, 15:47
  3. change glow plugs
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2010, 17:42
  4. how do i change the glow plugs
    By tim wood in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2008, 21:25
  5. where are the glow plugs? 1.9cdti 120
    By spartan80 in forum Engine & Drivetrain
    Last Post: 11th April 2008, 20:49
how to change glow plugs vauxhall vectra 1.9 cdti
changing glow plugs vectra 1.9 cdti
how to change glow plugs on a vauxhall vectra cdti
vectra glow plugs
vauxhall vectra glow plugs
vectra cdti glow plug change
vauxhall vectra 1.9 cdti glow plugs
vectra c glow plug removal
vectra 1.9glow plug position
changing vectra glow plugs
how to change glow plugs on vauxhall zafira 1.9 cdti
vectra c glow plugs
vectra glow plug change
glow plugs vauxhall vectra diesel
vauxhall vectra heater plugs
vauxhall vectra 1.9 glow plugs
https:www.vectra-c.comforumshowthread.php41346-how-to-change-glow-plugs-on-1-9cdti
vauxhall 1.9 cdti glow plug replacement
how to change glow plugs vectra 1.9cdti
changing vectra c glow plugs
vectra c glow plugs removal
how to change heater plugs on a vectra diesel
