Thread: i think i need anti roll bar bushes but!!
    Regular Member EURO G's Avatar
    n ireland
    confused i think i need anti roll bar bushes but!!
    would the perished anti roll bar bushes cause the car to steer funny and go into slight skids going into corners?
    nope...not perished antiroll bar bushes...sounds like you need to get your steering arms checked for play
    n ireland
    ive a mate from vauxhall looking at it for me tomorrow mark,so ill mention the steering arms would this cause the back end to come out when cornering?
    excessive speed would do all the above too
    Portadown, N.I.
    Is it the back end that's stepping out, esp' over a bit of rough road? Mine had that, it was the upper control arms at the rear and I also had 1 shot shocker. The ARB bushes will only make a knocking noise, they wont make the car step out.
    Tim
    n ireland
    [quote=spuddevans;502029]Is it the back end that's stepping out, esp' over a bit of rough road? Mine had that, it was the upper control arms at the rear and I also had 1 shot shocker. The ARB bushes will only make a knocking noise, they wont make the car step out.
    the back is coming out but on a normal road its not to rough etc,its very hard to explain its like hitting ice on the road or something
    Portadown, N.I.
    Mine started out not too bad, it'd only step out at the back over 50mph on a smooth road. But it got worse so that even going over a manhole would make it step out if I was going over 40.
    I really sounds like what happened with mine, like I said the cause on mine was the upper control arms at the rear, 35+vat each, and I had one rear shock also gone so had to get the both replaced. Mine always seemed to step out or slip to the drivers side, and it was the drivers side rear shock that was gone.
    Check to see if either of your rear shocks are leaking.
    Hope you get it sorted mate,
    Tim
    Regular Member jack's Avatar
    slaming doors since 1976
    spuddevans is this a common fault then if you have had problems too?
    ___________
    vectraburger 'n' fries plz
    LOL.. yes wearing top links and worn rear shocks are very common on vectra-c's as the miles increase....not dear to fix thou which is good..
    thats alright tho i know some models have faults such as suspension problems on sigs and such hows your gsi iv got a 2.2 sri and iv no plans to change it its as i want it after loads of mucking about with it i had a black 1 for a while and changed to this 1 but i just am abit low on power than everybody else but i like it.
  1. Anti-Roll Bar Bushes
    By Monkgti in forum Suspension, Wheels & Brakes
    Last Post: 2nd February 2013, 20:56
  2. Anti roll bar bushes
    By Mark-R in forum Handling & Braking
    Last Post: 27th April 2012, 14:13
  3. Anti Roll Bushes...Which ones?
    By n_hudson in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2009, 12:17
  4. anti roll bar bushes
    By mhvcbv in forum Suspension, Wheels & Brakes
    Last Post: 8th July 2008, 17:53
  5. Anti-Roll Bar Bushes-How??
    By Vaux-Man-G in forum Suspension, Wheels & Brakes
    Last Post: 29th June 2008, 20:09
vectra c rear anti roll bar bushes causing wheel play
