Results 1 to 3 of 3
Thread: Srut top bearing?
    Regular Member installer's Avatar
    Nottingham
    Default Srut top bearing?
    Right putting my ` I`m really thick` hat on here,
    I`ve the infamous suspension clunk at the front left.
    Replaced Antiroll bar links - no change
    Going to replace the antiroll bar mounting rubbers
    Going to oil the rad mounts
    Car has had spring mod done - but am going to clean pan and put some copper grease in the pan - then check condition of spring mod sleeve.
    Then was asking about a bolt size and this post came up
    "working at vx i sort that problem out all the time,strut top bearings.garenteed.common on all vectra c's.even straight from the factory"
    in this thread - http://www.vectra-c.com/forum/showthread.php?t=41239
    So where exactly is this strut top bearing,is it known as something else,can it be repaired or does it need greasing - if so with copper grease,or should it be replaced????
    Or if I put new shocks and springs on would this bearing get replaced as being part of the shock - or is that barking up the wrong tree.
    Should I wait till all the above is dnoe before I take it to get aligned at a `Hunter` place?
    Please help as I`m short on cash and am trying to do as much as possible on me tod.
    Ashington, Northumberland
    The 'top mounts' are at the very top of the strut where it mounts up into the wing. They wouldn't normally be replaced when renewing the springs and/or shocks unless they needed doing or you asked for them to be renewed. To see if there is excess play, lift the bonnet and push hard down on the wing of the car and watch the upward movement of the top of the strut where mounted into the wing. Alternatively, jack the wheel up and use a bar under the wheel to lever it up, again watching for excess movement upwards at the top of the strut. HTH
    Nottingham
    No movement with the bonnet up,but am going to tahe it apart next week with a mate and have a good look at it and try to pin point it.
    Mate would be gobsmacked if it was ar bushes on a car thats 3 1/2 years old and done 30000 miles.
    So now I don`t know whether to do my ar bushes.
    I am convinced after listening to it last night that it`s suspension related.
    Anyone else with advice to my questions in post 1
  1. Possible wheel bearing!
    By davidjoneil in forum Suspension, Wheels & Brakes
    Last Post: 29th March 2011, 11:18
  2. Top mount bearing?
    By goafer in forum Suspension, Wheels & Brakes
    Last Post: 6th June 2010, 08:57
  3. bearing gone
    By rave5 in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2009, 10:50
  4. Bye Bye Bearing
    By Adamant in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2008, 12:47
