Results 1 to 10 of 14
Thread: Transfering Regal strut brace from 1.8sxi into 1.9 CDTI problems
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Transfering Regal strut brace from 1.8sxi into 1.9 CDTI problems
    Hi,
    i am trying to transfer my Regal Strut Brace into my new 1.9 CDTI 150
    and have hit a problem. The near side mount has a bracket attached to it holding the ECU and gets in the way of the strut brace. Anyone know what the best workaround for this is?
    Will I have to chop a bit out of the bracket? or does any one have a bettter answer?
    cheers for any help
    Regular Member mushy2007's Avatar
    Liverpool
    search for it, spoons swapped his over the other month.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by mushy2007 View Post
    Found it:
    http://forum.vectra-c.com/showthread...ht=strut+brace
    but it does not answer my question
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    What ecu is it? I thought there were only IDS+ sensors mounted on shock mounts?
    Sunny Dartmoor
    Need some pic's to see what you mean........
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Ok got some pics
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    just bolt it on the top that what i did. with longer bolts. just place a washer under each bolt hole to take up the gap from the rased bits on the bracket. only needed 1 washer each side
    Northampton
    Engine : A20DTH
    Mileage : 88000
    The upright on the bracket seems to get in the way of the holes matching up
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by aerodynamic18 View Post
    Was it the same bracket? as it the brace is fouled by the upright on the bracket
    Think I need to take a grinder to both, then it will fit!
    Aug 2007
    Lisburn, N.Ireland
    yea it was the same bracket but mine i got from LMF but it looks exactly the same
  1. Regal Strut Brace
    By Brocks in forum Parts for sale
    Last Post: 4th July 2008, 23:39
  2. VXRD Regal Strut Brace - For Sale
    By spoons in forum Parts for sale
    Last Post: 15th January 2008, 13:45
  3. Strut Brace.... ?????
    By JonR in forum General Chat
    Last Post: 31st December 2007, 21:25
  4. Regal Strut Brace
    By Silver V in forum Parts for sale
    Last Post: 17th November 2007, 15:48
