Results 1 to 10 of 20
Thread: Help: Installing HK Drive & Play
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Default Help: Installing HK Drive & Play
    After looking at all the options to get the iPod installed in the car I have finally decided on a Harmon Kardon Drive and Play (only £31 delivered from ebay). Hopefully it will come tomorow so fancy installing it in my lunch hour and did a bit of investigating tonight. But...
    What type of aerial adapter do I need for the back of my CD30??
    And how do you get that black plastic thing off to get the white aerial plug out???
    Finally how do you get the ashtray out. I have pulled it but don't want to break it. It seems to be attached on the left and right sides (circled in red)?
    Thanks, Mark
    Oct 2007
    Reading
    Vehicle : SAAB 93 Estate, Vectra C Estate
    Trim : LINEAR SE, Elite
    Engine : Z19DTH, Z22YH
    Year : 08,08
    Aerial adapter, not sure about the drive and play, maybe some else can advise:
    There is a clip on the side of the aerial plug looking at your picture on the right side I think, just press it in and pull the aerial connection at the same time will come of easily.
    Ashtray just pull gently it will almost fall out.
    Jun 2006
    North West
    InnerZone: Thanks for the reply
    aerial: I didn't see the clip last night. It was dark though :-)
    ashtray: Do I need to remove any other trim?
    I only removed the plastic gear gaiter surround and loosened the lighter surround.
    Do you pull it straight up?
    I gave it a good tug and it didn't fancy moving. Maybe I should go to the gym this morning to warm up first :-)
    aerial adapter: I thinks its a fakra aerial, is it know by any other name? Gonna try and find one at halfords this lunchtime.
    Oct 2007
    Reading
    Year : 08,08
    Quote Originally Posted by Marky View Post
    Re the aerial (possible correction) there is a clip on the side of the black aerial plug fitting looking at your picture on the right side I think, just press it in or push it out with a small screwdriver (sorry can't remember which way it goes) and pull the aerial connection at the same time will come of easily.
    To remove the ashtray remove the plastic gear gaiter surround (as you have done), the ashtray it is secured by two clips under the red circles you show, should just pull straight out and up.
    The aerial is a Fakra so you might need Fakra to normal car aerial and back adapters to fit the HK which I think uses normal car aerial connectors, but you need to check.
    Assuming the adapters and the HK modulator pass 12V to the car aerial it should work OK, it they don't pass 12V to the aerial you may need one of these as well, Fakra powered adapter.
    Lot more info here:
    http://forum.vectra-c.com/showthread.php?t=15326
    Last edited by Inner Zone; 19th February 2008 at 10:25. Reason: Additions and possible correction
    Regular Member SignumPhil's Avatar
    Luton, Beds
    When I fitted mine, it came with Fara to normal adaptors, so you're OK on that one. It also passes 12v to the aerial, so no worries there. Also be aware that you can connect to a switched 12v supply as well as a permanent one -but you don't have to. If you do, every time you switch on the car, the H/K powers up and starts playing. Next time I pull my glove box out I need to change that!
    Phil
    Jun 2006
    North West
    InnerZone: Thanks for the help. I managed to get the ashtray out by trying a bit harder :-)
    Jun 2006
    North West
    SignumPhil: Can't see any convertors in my kit. There are a couple of silver plugs with no wires. Don't know if theyre them.
    Also are you wanting to change yours TO a switched feed?? or back to a permanent??
    I was planning to connect the Yellow 12v and the ground via a scotchlock to the 12v and ground on the CD30 stereo harness. Then the red ACC to the Black feed on the Accesory/ciggy lighter (again using a scotch lock)
    Luton, Beds
    The silver plugs should be the things. I can't quite remmber what they looked like on mine, though!
    the ACC one is the one that causes it to switch on/off. You can still turn it on manually, though.
    I've got a Nokia car kit, so I stole power from there.
    See my piccies here:
    http://www.vectra-c.com/forum/showthread.php?t=33923
    Phil
    Jun 2006
    North West
    These are what came in the box. Sorry about the rubbish picture:
    The two silver plugs look like ISO-DIN convertors?
    I assume to use the switched power I connect all three wires up (12v, ACC and GRND)?
    Sorry, I am a bit of a car electronics noob.
    Oct 2007
    Reading
    Year : 08,08
    The two silver connectors are DIN to normal car and normal car to DIN converters, you will need the Fakra to normal and the normal to Fakra as I linked to above. The website was a suggestion not a recommendation you might get them locally in a car audio shop or dare I say Halfords.
  1. Harman Kardon Drive + play
    By 1.9Cdti Elite in forum Electrical & ICE (including SatNav)
    Last Post: 20th November 2009, 06:28
  2. Harman/Kardon IPOD Drive + Play
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2008, 19:43
  3. HK Drive & Play Sound issues
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2008, 10:24
  4. Drive & Play install
    By SignumPhil in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2007, 14:15
  5. HK Drive and Play install
    By DNS in forum Electrical & ICE (including SatNav)
    Last Post: 2nd November 2007, 10:58
