Results 1 to 10 of 22
Thread: F40 gearbox
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    Default F40 gearbox
    had a problem with going into 3rd gear over the past month or so, a crunching felling thro the gear lever (no a tunit box wont do )
    the car has done 4700 miles 9 month old its SRI 3.0 CDTi
    so called VX and book it in for today first thing
    the lad took it out for 10mins staright back into the workshop
    up on the ramps left it there for 30mins drop it down drove it out
    so here gose the old linkage story shove it and see
    Sir i totaly agreey with you about the gears .I have phone VX talk to them and we are going to replace the gearbox with a new one.Will ring you when it comes in
    brillant
    will they put a new clutch and thrust bearing in aswell or is it best to ask when they ring me to bring it in
    Blimey, that seemed easy enough. I bet that surprised you?
    I'd phone them about the Clutch and Bearing mate, at least you'd know then.
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    that was at hartwell on chester rd old trafford today
    i will aks them now about clutch and bearings
    I'll bear them in mind if I have any more problems.
    Regular Member The Doc's Avatar
    'Norf Yorks.
    They did mine too no worries. Posted about month ago mate
    1.9 CDTi 150bhp.
    'Norf Yorks.
    They put a complete new clutch in too
    Nice one Ian - bet you're happy. One thing mine is going in for in January is a notchiness in my gear changes, not 3rd in particular and not as bad as yours by the sounds of it.
    Correct me if I'm wrong anyone, but is the 6 speed in the 3.0 CDTi a different one to the 6 speed in the 1.9 CDTi/2.0T? I know mine is an F40, but thought the one in the 3.0 CDTi was different?
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    no as far as i know the 6 speed box is the F40
    but there is a man who will know matt smith so we will have to wait and then we will get the full info of him
    come on matt where are you
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    Quote Originally Posted by CDTi
    1.9 CDTi 150bhp.
    yes i remember reading that post CDTi
    and i was talking to ABYSS about it around the same time you had yours done because ABYSS is have the same problem as me
    Quote Originally Posted by ian_c
    Right, just wanted to check - to see if we can compare 'faults' with gearboxes between all the 6 speeds. I'll have a dig in my TIS as I'm sure the six speed in the 3.0 CDTi is different.
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Gearbox and Gearbox Oil question
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2011, 17:01
f40wr wide range
Vauxhall F40cr gearbox
saab f40 gear same as vectra
