Thread: bonnet keeps opening!!
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Default bonnet keeps opening!!
    hi ever since i put some water in the washer bottle and shut the bonnet i have encountered a problem. i went out that night in the car to wake up the next morning to find the bonnet up but only on the latch like when you have just released it!! so i shut it again went out, came back again and it had done it again!! does anybody have any idea what it could be?
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Check the release handle in the car has returned to the correct position. that happened to me once and i noticed the handle was sticking.
    Mileage : 000
    The location hole that the mating part from the bonnet sounds like it has "stuck" there is a sort of spring that goes diagonaly across the hole and it holds the "spike" from the bonnet in firmly. It sounds like it might need som grease or the likes on it to free it up, worth having a look at it .
    Feb 2007
    Quote Originally Posted by Keithy View Post
    i did that today after it happened again but not been out in it since!! if it does it again whats the best thing to do?
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    check the cable run right back to inside the car and check for any damage you might need a new cable worse case
    Feb 2007
    Quote Originally Posted by ed taylor View Post
    cheers ed will have a look at that tommorrow
    Jan 2008
    Dundee
    As ed taylor say's check the lock for corrosion, free it then grease it
  1. Bonnet opening
    By bigstorer in forum Bodywork & Interior
    Last Post: 11th July 2011, 08:01
  2. Opening the key fob?!
    By robk6112 in forum Vectra C / Signum Troubleshooting
    Last Post: 13th June 2011, 21:32
  3. Boot Opening
    By dc6839 in forum Bodywork & Interior
    Last Post: 26th January 2011, 20:46
  4. Opening windows with key-fob
    By ghostrider in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2008, 21:01
