Results 1 to 10 of 15
Thread: Headlight aiming
    Regular Member Bucko's Avatar
    Pudsey
    Default Headlight aiming
    I keep hearing poeple saying they have done the headlight aiming mod.
    What? How? Where?
    basically means that you align the headlamps as high as legally possible...most are set low..
    Regular Member Mac's Avatar
    Jan 2008
    Stevenage
    if you mean being able to adjust the angle of the bulbs its the little rotary knob thing by the headlight switch next to the one that dims the interior lights.
    nope..adjusting the alignment of the reflectors themselves by moving the lamps manual adjusters..
    Mileage : 000
    Duncan did a bit of a "how to" on this didn,t he. I dont know the thread though.
    Regular Member LJ sxi-nav's Avatar
    Winchester
    Pudsey
    Cheers for this mateys. Unfortuneately mine has the Xenon self adjusting ones. Just thought I might be able to adjust the "normal" position slightly higher.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Where abouts are the Allen bolt adjusters located? Are they on the headlight units themselves?
    Gazza4
    Regular Member BigLad's Avatar
    Feb 2007
    30,000ft by day, bed at night
    Yeah they are if I remember, on the Pre-facelift they are coloured yellow and are plastic rather than 'bolts'. If you look closely on the plastic too the side of the adjusters you will see arrows for left/right and up/down.
    May 2007
    sheffield
    Does anyone have the measurements for the set up of the headlights I have a 06 SRI 1.9 cdti estate. it seems that after a knock on the front end I have one light aiming higher than the other, not keen of paying Vx to do this as its easy if you have the measuremnts!!
    cheers
  1. Aiming to look like this
    By BobbyValentino in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2013, 15:05
  2. how do you de-fog a headlight?????
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2009, 21:21
  3. Headlight mod .. need help
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2007, 19:18
