Results 1 to 10 of 26
Thread: Rattling Turbo
    south wales
    Default Rattling Turbo
    sorry for posting to many threads but away from home and not much chance to get on here as much,theres a rattle from the turbo i think,took the heat shield of and can hear a constant rattle,sounds like turbo is there anything else there could be its anoying,thanks all for the replys
    pray it's the heatsheild...if it's the turbo then it could be worn shaft bearings or a loose poppet valve..
    get some leather heatproof gloves and try holding the heatsheild still to see if the rattling stops..
    south wales
    i had the heat shield of the other day and the rattle was still there does that mean its the turbo,cheers for the replys howdo you know so much
    been working on cars for far to many years....
    check for loose lower heatsheilds as well and loose covers in the area first...before condemning the turbo...check hard..turbo's aren't cheap..
    south wales
    400 pound from vauxhall with actuator,it seems to be the bit the turbo bolts to right of the turbo but obviously cant tell for sure,can a turbo rattle,worried now
    Regular Member The-Bandit's Avatar
    Mar 2007
    snake hunting
    sounds like the bearings to me mate inside.
    I always let my car run on a bout 30 secs when i pull up to let the oil circulate and turbo wind down.........
    P.M Duncan mate he had a turbo prob a few months back, he may be able to help you.
    a turbo can rattle, but you say it's the plate it's mounted to..??..or the bit to the right of the turbo?..thats the downpipe for the exhaust.. held in place with 3 nuts.. one of the could have come loose letting the downpipe rattle on it's steel gasket..
    try holding that pipe left hard while seeing if the rattle stops..
    Quote Originally Posted by ninja636 View Post
    you can check this by removing the downpipe and seeing if there's any sideplay in the shaft.. if there is even minimal bearing play it's usually accompanied with massive oil consumption
    south wales
    my oil needs topping up every couple of months or so does that soundwrong
    nope...if it was using oil it'd be daily top-ups..
  1. Rattling noise
    By Lozza in forum Engine & Drivetrain
    Last Post: 10th May 2012, 18:34
  2. still rattling!!
    By jofenan in forum Engine & Drivetrain
    Last Post: 19th January 2011, 23:25
  3. rattling
    By SilVectra in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2010, 20:53
  4. Rattling vvt.
    By mattDY57 in forum Engine & Drivetrain
    Last Post: 8th June 2009, 19:57
  5. rattling noise
    By signumboy in forum Engine & Drivetrain
    Last Post: 6th February 2008, 20:28
