I didn't write that...........
cheers, will check at the weekend....
The Vectra has so many things that can make the knocking noise and so many tings that can be changed to try and solve it.
1)My RAD mounts make a noise and couldn't figure out how to change them and didn't want to rip the old ones off and cause damage elsewhere, so I just keep them oiled/WD40.
2)Changed the springs and dampers all round and got a knocking noise from the front, changed ATRBL and it was still there and then changed the top strut bearings and that got rid of most of the noise, but I've still got a light noise when I turn the steering. Got the spring seat mod fitted, but they came off the old suspension so where pretty tacky and will need changing at some point.
[QUOTE=mark1319;501228]The Vectra has so many things that can make the knocking noise and so many tings that can be changed to try and solve it.
QUOTE]
Chasing the holy grail then.
When does the noise happen? Is it going over bumps, turning corners, pulling away from standstill or is it a constant type of thing?
