Results 1 to 10 of 21
Thread: Rear Camber Angle Wierd
    south wales
    Default Rear Camber Angle Wierd
    ON my off side rear wheel the camber is well out compared to the other wheel,is this normal or is something wrong,one wheel is relativley straight and the other side is on an angle,the other thing is i have noticed my handling crap if going around a round about slightly fast the back end slips out and my tyres are fine and it seems to be on the side the camber is out is this related cheers all,
    Regular Member gipps's Avatar
    maidenhead
    Thumbs up
    Hi mate, the exact same thing is wrong with mine, only on right hand bends.
    When you turn does it feel like the suspension is a tad lose somewhere and do you get a knocking noise?
    It's quite a common problem on the Vectra's peeps. Most Vectra C's suffer from excessive tyre wear on the inside of the rear wheels. It's something to check regularly as far as I'm concerned.
    I can't comment if it's a problem on the Signum's.
    south wales
    feels boaty and doesn't grip that good,i had a quick feel of the spring and that all seems fine,not sure about knock as i have stuff on parcel shelf but will move it tomorrow,can hear alot of road noise from back like a wheel bearing,on one mini roundabout i did a 180 cause the back slipped out,and on bumps does yours move over the road alot,its the left wheel on mine the camber is out and yeah turning into a right bend or roundabout doesn't feel right
    It sounds to me like the rear shock has leaked it's oil matey. I had this on my Vec and so has a lot of others.
    Get someone to follow you and see if the rear wheels are bouncing as you drive along. If they are bouncing it will absolutely eat tyres if not sorted.
    maidenhead
    confused
    Thanks for that, but what about the knocking noise and the feel of loose suspension, any ideas?
    Another common fault on the pre-facelifts is a knocking boot lid. There's loads of threads on here about a knocking sound from the rear and most have been a faulty boot catch. Me included.
    upper rear suspension arms....the outer void bushes will be worn..
    change the upper arms and get the car aligned for toe and camber....use one of the local firms found on here www.alignmycar.co.uk to get a 100% quality job done..
    south wales
    thanks mate will look at that tomorrow,tried bouncing the rear end but seems fine but i suppose your not really doing much bouncing it
    nope you need to be rocking the wheel 12/6 o clock to feel it...
  1. For Sale: Rear cigarette lighter & steering angle sensor
    By pszczo in forum Parts for sale
    Last Post: 30th October 2012, 07:05
  2. Rear camber
    By Fig-sri in forum Handling & Braking
    Last Post: 26th February 2011, 15:05
  3. rear camber
    By tditony in forum Suspension, Wheels & Brakes
    Last Post: 2nd June 2009, 18:37
  4. Rear Camber
    By Daywalker in forum Suspension, Wheels & Brakes
    Last Post: 24th June 2008, 14:24
  5. SRi rear camber
    By wrightgj in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2005, 19:14
camber angle on vectra c
vectra c rear wheel toe angle
