Thread: Dreaded limp home mode
    May 2006
    scotland
    Default Dreaded limp home mode
    Well, exactly 1 month out of Warranty, my SRI 1.9 cdti 150 was driving jus fine then started pulling as if the brakes were binding, no real pull, then next thing, the spanner light on dash. I stopped the car, re cycled ignition an has been fine since, covered almost 2 miles and all seemed fine. Umm. Car has never been modified, will have 2 monitor from now on.
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Take your plastic engine cover off & look down between the inlet manifold & the cylinder head for the infamous Swirl valve issue..
    http://forum.vectra-c.com/showthread.php?t=33511
    Could also be Egr valve related + Many other things, Only true way to find out if there is no visible notification is to get the fault Codes read !!
    Dean
    As above matey. The only way to know for sure is to have the fault codes read. It could be any number of things.
    As you're just out of warranty, I'd be very surprised if Vx didn't help you out with repair costs.
    May 2006
    scotland
    ok thanks lads
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    As a matter of interest how many miles has your car done?
    May 2006
    scotland
    Ian, only 25k miles. Full Vauxhall service history.
    I was choked with the cold so my hearing was a bit distant but it felt like the turbo was not spooling up at all. After ignition re-cycle all appeared fine. Have not been in it today.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    what type of use is it getting, motorway or lots of short cold stop/starts,low mileage short stop starts are a killer with cdti,s .vx admit its a problem with this engine.
    May 2006
    scotland
    All motorway miles (40 mile round trip per day), average 60 or 70 Mph, its not thrashed but lets just say it gets used from what I would say is the best for the engine.
    May 2006
    scotland
    Well I went a 30 mile run today and it was perfect. No spanner light, running with maximum power. Most peculiar
    Regular Member grumpano's Avatar
    North West
    Just see how it goes mate.If you take it to VX they will just scratch their heads and tell you no fault found.
  1. limp home mode
    By FRANKA in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2011, 12:04
  2. help dreaded limp mode
    By iwtand in forum Engine & Drivetrain
    Last Post: 28th March 2011, 23:08
  3. Limp Home Mode
    By Liam Murnaghan in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2009, 00:43
  4. Limp Home mode
    By stevesview in forum Engine & Drivetrain
    Last Post: 15th July 2008, 17:20
  5. help. limp home mode
    By mad4stela in forum Engine & Drivetrain
    Last Post: 20th May 2007, 18:54
vectrac.com vectra cdti limp mode when cold www.vectra-c.com
