Results 1 to 10 of 21
Thread: Heater only blows hot
    Regular Member GoldenWonder's Avatar
    Durham
    Default Heater only blows hot
    Hi,
    My 2004 1.9 CDTi seems to only blow hot air. Regardless of what the temparature controls is set to hot air comes out! This only seems to have happened recently.
    Everything else seems to work - fans, distribution etc and the engine temp is always around 80 (as it always has been) Can't tell whether the aircon works as the hot air would hide that anyway!
    Is it possible the temparature control is faulty in some way? it doesn't look like theres much to it!
    If so, will one from a 2006 model fit my 2004 as they look identical and I've seen a few for sale on ebay for reasonable prices.
    Jul 2006
    Quote Originally Posted by GoldenWonder View Post
    H
    Certainly sounds like it
    Should be identical, just make sure you get the right model - ie with/without aircon, with/without climate control etc.
    HTH
    Durham
    Cheers - Vx are asking around £95 for the part so I want to make sure I get the right one!
    Jul 2006
    Might be an idea to ask Vx (or post up in the Part Numbers section here) what the right part number is, then you can be sure you get the right one on ebay
    Durham
    Good idea - Vx said its the same part right the way up unless its a climate control one, then it changes with the facelift.
    Got one from Ebay for £39 delivered - cheaper than Vx but I hope it solves the problem.
    The Vx guy seemed to think it was a fairly common problem but I haven't seen much of it mentioned on here?
    Jul 2006
    I've not heard of this problem, I don't think. The heater fan motor is quite a common fault, but no the heater itself.....
    Good luck to you though
    Durham
    Well I'm assuming its the controls at fault. Everything seems to be working as normal - just turning the dial to cold has no effect!
    Unless theres a valve or something that closes when you switch the heater off and thats faulty? Not sure how this works
    there's a servo pack that drives the air mix flaps..that could be faulty as could the temp sensing probe..
    Durham
    B-gger! I should have guessed it wouldn't be simple!
    Whereabouts are the servo pack and temp sensor?
    I miss the old cable systems for heating controls...
    Durham
    Isn't it always the case...
    Took the glovebox out and 'tinkered' with the aix mix motor and all seemed OK, just not actually moving when i turned the heater control.
    Had a cup of tea whilst thinking, squirted some WD40 on the motor joints for good measure and it started working again!
    Anyone want a heater control panel from a 2006 Vectra? - I will have one spare soon. No reasonable offer refused
  1. Heater blows cold when idling
    By manimal in forum Bodywork & Interior
    Last Post: 16th February 2012, 02:36
  2. Heater blows hot only
    By laingyc in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2011, 10:57
  3. Heater only blows cold
    By Harry Hammer in forum Vectra C / Signum Troubleshooting
    Last Post: 21st March 2011, 20:55
  4. Heater blows hot & cold
    Last Post: 22nd November 2010, 23:45
  5. Heater only blows cold
    By b-e-r-t in forum Electrical & ICE (including SatNav)
    Last Post: 15th April 2008, 13:30
vectra c heater only blows hot
vectra heater actuator
vauxhall insignia heating control actuator
vectra c heater actuator cogs
vectra c heater actuator red spindle arm
