Thread: Emission light V6 CDTI
    EVERYWHERE
    Default Emission light V6 CDTI
    A couple of times just recently the emission light has come on.Sometimes when accelerating steadily uphill and others when the car is being reversed onto the driveway using nothing more than tick-over!
    Usually just switching off and waiting a few minutes and switching on again will solve the problem.But once or twice I have had to warm the engine right up and then switch off and restart for the light to go off.Usually it is only the emission light that comes on (no spanner light).
    Any ideas?
    I had the emission light come on on my CDTi 150 and it turned out to be a faulty injector. It could be a number of things though matey.
    If the emissions light ever flashes on anyone you must pull over and get recovered as the CAT will be getting damaged.
    EVERYWHERE
    Good advice!
    There's never any excess black smoke or other symptom.It did once drop into 'limp mode' when the light came on.But otherwise runs as normal,even with the light on!
    I simply don't know enough about the V6 CDTi to help enough I'm afraid.
    The only thing I can think of about the V6 CDTi is that the little valve that sits on top of the ECU can become blocked, but I can't remember what the symptoms are/were. One of the V6 boyz or girlz will be along shortly I'm sure.
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    My mate at work runs an 05 sri v6 cdti and has just experienced a simular fault on his, seems to be over boosting when watching data list on tech 2,spoke to technical yesterday and could have a turbo fault which is common on these,seems the variable vain part of the turbo sticks internally causing overboost, luckily his is still under warranty andhaving new turbo next week May be worth getting it checked out.
    EVERYWHERE
    Quote Originally Posted by alanv6 View Post
    I had the turbo and sensor replaced on mine last Summer,so it should still be covered by 12 month warranty.Not had any problems over the last few days,but I'll probably get it checked out anyway.
    AYLESBURY
    Had same symptoms on my v6 cdti on a 54 plate,turned out high pressure fuel pump was under fuelling,hence emission light comes on.Took garage 3 attempts to diagnose problem [no fault codes come up]only done 30,000 miles brand new pump on warranty.
  1. Emission light on
    By Porl in forum Engine & Drivetrain
    Last Post: 11th February 2013, 23:10
  2. Exhaust emission light on 1.9 CDTi
    By Andy R in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2012, 21:42
  3. spanner light reset emission light now on HELP!
    By johnny boy67 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2009, 12:07
  4. Emission light 1.9 cdti 120 helped
    By Kieran1981 in forum Engine & Drivetrain
    Last Post: 17th July 2009, 18:59
  5. help with emission light
    By wilsons 1.8sxi in forum Engine & Drivetrain
    Last Post: 10th July 2008, 02:02
v6 vectra cdti emissons light on whilst engine running
