Results 1 to 10 of 11
Thread: Exorcism required on wing mirrors...
    Regular Member Harry's Avatar
    Uxbridge, London
    Default Exorcism required on wing mirrors...
    Hi all,
    Sophie's wing mirrors on the vectra are acting up, when you adjust the passenger side one it's fine, works as it should, but when you push down the button to adjust the drivers side and then make any changes it turns both the drivers side and the passengers side.
    I'm sure they were working fine just the other day when i was driving it.
    Bit spooky.
    Anybody else ever had this? Is there anything i can do other than taking it to the dealer?
    Don't think the car likes the recent spell of frost!
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    I think this is normal behaviour as mine does it, I believe that they are designed to move in unison in order to help - b*ggered if it does in my case though!
    it's normal Harry.. they all do it...
    ...adjust the drivers first, then the passengers....
    Jun 2006
    Somewhere...
    I gave up with mine and "adjusted" my body to suit them!
    Uxbridge, London
    Quote Originally Posted by JuzzyD View Post
    OMG!!! i can't believe that it's normal....i've never noticed it before! how can that be?????
    and as per Juzzy's post, how is this 'feature' meant to help?
    Jun 2006
    Somewhere...
    I think there is meant to be some form of corresponding action from the opposite mirror - but I must like my mirrors different to VX as it took ages to get them anywhere near.
    To be honest I cheated and "forced" them externally...
    Regular Member rmt's Avatar
    Cambridgeshire
    Lol lovely way to damage them! :P I've never noticed this happening with mine.. and the only half occasionally drives mine... she'd whine immensly!
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Perfectly normal, the only time I find it helps is when reversing off of certain drives, you can point them both down together.
    Cambridgeshire
    lol, now I know it might help then! as to get on my drive i usually have to point them down!
    My previous 2004 Elegance, you could control each mirror independantly, but
    my current 2006 Elite is as mentioned above. Personally I prefered the set
    up of my previous Vectra.
    To quote from my Elegance handbook (2003 edition):-
    Adjusting exterior mirrors: Press switch for left or right hand mirror:
    four-way switch operates the corresponding mirror.
    To quote from my Elite handbook (2007 edition):-
    Adjusting exterior mirrors: If the outer mirror switch is pressed the
    four-way switch operates the driver and front passenger mirrors, and if the
    inner mirror switch is pressed it only operates the front passenger mirror.
  1. Wing Mirrors anyone?
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 7th March 2011, 09:32
  2. wing mirrors!!
    By ross4705 in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2011, 22:47
  3. wing mirrors
    By simon5800 in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2007, 01:52
  4. Help required asap with wing mirrors
    By Matt21385 in forum Styling
    Last Post: 29th May 2006, 23:09
