Thread: Where are the rear fog lamp fuses please
    London
    Unhappy Where are the rear fog lamp fuses please
    Does anyone know as I have my near side fog not working and the bulb is A ok.
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    Quote Originally Posted by Marskeman View Post
    That's as it should be, only the o/s fog light is meant to work.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    The n/side isn't wired in, only the o/side!
    London
    Oh I thought I found my problem. I have an intermittent blown bulb symbol on my dash. I cannot find a blown bulb anywhere.
    11 Post(s)
    Take each bulb out (one at a time) and try cleaning the terminals on both the bulb and cluster.
    London
    Thanks will do.
    Single fog light fitted to show you where the car is - it should be on the off side only, so when you're on a motorway in thick fog you can tell where the other car is...
    I didn't know this when I had my first car (a little 1 litre Nissan Micra ) so thought I'd be clever and wired in another one on the other side to replace the blank...
    What can I say - I like symmetry..... :geek:
    Regular Member dave b's Avatar
    Nov 2007
    Wigan, Lancs
    Trim : Design LPG
    Engine : 1.8 vvt
    Mileage : 196,000+
    If you want to have a n/s rear fog just scocthlok a short piece of cable into the blue/black cable in the wiring loom below the n/s light & connect the other end to the terminal in the bulbholder multiplug that doesn't have a cable leading to it.(Bottom one from memory) Hey Presto ! two rear fogs & doesn't bring up a bulb error. I've carried out this mod on two "C's" & it works a treat.
    11 Post(s)
    Quote Originally Posted by David K Boydell View Post
    Is that on Vectra's with the basic bulb check, or on Vectra's with the radio display telling you which particular bulb has actually blown?
    London
    Its the bulb symbol on the dashboard with an exclamation mark in the middle
  1. Rear fog Lamp N/s
    By Robbo278 in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2009, 02:28
  2. Rear Fog Lamp Problem???
    By lightfx in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2009, 00:43
  3. sri rear lamp
    By PAULMAC77 in forum General Chat
    Last Post: 6th October 2008, 14:54
  4. Rear Fog Lamp
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2006, 23:11
vectra c rear fog light not working
zafira b rear fog lamp fuse
vauxhall vectra c facelift nearside rear foglamp not working bulb ok
were is 2010 vauxhall corsa rear fog light fuses
do you need a fuse for rear fog light in a Corsa
07 astra rear foglight problems
corsa d rear fog light fuse
left fog fuse vectra c
astra rear fog light not working
2008 astra rear fog light fuse
rear fog light fuse corsa 54 reg where is it
vectra rear fog lamps
corsa Vxr rear fog light fuse
vectra c foglight fuse
show picture of near side fog light and fuse o n 04 vectra
rear fog light fuse on vauxhall zafira b
corsa d fog d fog lights not working
vectra c fog light fuse
fuse for fog lamp opel astra 2008
vauxha corsa 2012 rear fog lamp fuse
vauxhall astra van rear fog light fuse
where is a vauxhall vectra c rear fog light
opel zafira fuse for fog light
fog lights fuse on vauxhall zafira
2005 vauxhall astra rear fog lights fuse
