Hi,
Pls help, my cruise control is not working anymore, can anyone help me with how 2 repair it??
Hi,
popular causes are the clutch switch and the brake pedal switch..both of which you can test by raising the pedals up from underneath with your toe while driving and trying to engage the CC...
if it's either of them then it'll just need the return spring modding with the updated parts
After a while there maybe wear to the plunger on the switches on the clutch and brake pedals, the problem I had was that you could turn CC on but would turn off straight away due to the plunger not traveling far enough. So as a no cost fix, I simply superglued a small washer to the top of the plunger on the switch of the clutch pedal, CC now works without any problems.
Check out the clutch spring thread it might be the answer if your car is a manual.
http://forum.vectra-c.com/showthread...542#post534542
