Thread: Cruise control not working
    Regular Member tommyk999's Avatar
    May 2007
    Oxford
    Default Cruise control not working
    Hi,
    Pls help, my cruise control is not working anymore, can anyone help me with how 2 repair it??
    popular causes are the clutch switch and the brake pedal switch..both of which you can test by raising the pedals up from underneath with your toe while driving and trying to engage the CC...
    if it's either of them then it'll just need the return spring modding with the updated parts
    Bedfordshire
    After a while there maybe wear to the plunger on the switches on the clutch and brake pedals, the problem I had was that you could turn CC on but would turn off straight away due to the plunger not traveling far enough. So as a no cost fix, I simply superglued a small washer to the top of the plunger on the switch of the clutch pedal, CC now works without any problems.
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Talking
    Check out the clutch spring thread it might be the answer if your car is a manual.
    http://forum.vectra-c.com/showthread...542#post534542
  1. cruise control not working
    By bigsteve3.0v6 in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2011, 21:53
  2. Cruise Control not working :(
    By Princess D in forum Vectra C / Signum Troubleshooting
    Last Post: 14th January 2011, 16:16
  3. Cruise Control - working again!!?
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2009, 19:30
  4. Cruise Control not working
    By jonnyc in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2007, 04:53
  5. Cruise control not working
    By armoured farmer in forum Vectra C / Signum Car Chat
    Last Post: 6th August 2006, 21:07
vectra cruise control not working
cruise control not working vectra c
vauxhall vectra c cruise control not working
