Thread: Possible egr problems??
    Feb 2007
    coatbridge
    Default Possible egr problems??
    Hi,
    Think this could be a egr problem looked at other posts an it seems similar.
    Last night my 1.9cdti revved only to 2000 revs with my foot on the floor?
    also happened the other day pulling out of a junction couldn't move at all! Scary moment
    Turned the car off then on and still the same it finally kicked in a few minutes later!
    could this be the egr valve?
    Regular Member justyb's Avatar
    wigan
    yeap say so sounds like mine did m8
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    was the engine managment light on in the tacho display symbol of a spanner?
    Feb 2007
    coatbridge
    no spanner
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Could be, if the EGR valve jammed open it would definatly reduce power but would would not hurt fuel economy. If it jams closed the opposite would occur, no drop in power or even an increase and a big increase in the amount of fuel being used.
    Take the hose off the inlet manifold and you'll find a butterfly valve just inside the manifold. Spray a little WD40 on the valve at top and bottom and exercise it. If it's just this valve that's sticking that should sort it, otherwise you'll have to trip to the dealers.
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
