Results 1 to 10 of 20
Thread: Oil and fuel filter Change on a CDTi 3.0 V6
    East Anglia
    Question Oil and fuel filter Change on a CDTi 3.0 V6
    The time has come for an oil change on my 2004 Vectra CDTi 3.0 V6 and I'm after a few tips. I changed the oil on loads of previous cars before, but am I likely to have any problems with the Vectra's undertray? Is there an inspection flap to get to the sump plug?
    I've got a filter from Autovaux, £23 for the proper GM one, but before I start rolling round on the floor can anyone tell me where its located? I presume its in a metal canister or something? Is it ok to get to?
    Also I've got a fuel filter, is that going to be any problem? Do these cars need bleeding or do you just fill the filter with diesel (the best you can) before fitting and let it sort itself out.
    Many thanks, any input is much appreciated.
    Pete
    Regular Member BigLad's Avatar
    Feb 2007
    30,000ft by day, bed at night
    Can anyone help, I wouldn't mind knowing as well.
    Leicester
    From memory, the oil filter is fitted from underneath towards the tight hand side and I am sure it is at the front of the block.
    Regular Member 30ltr nutter's Avatar
    dunstable
    hi the oil filter is located at the front of the engine meaning near radiator on the drivers side the under tray has to be dropped down as there is no inspection hole from what i can remember. changine the fuel filter is harder to change only due to getting the car started again i would suggest u fill the housing with fuel after changing the filter then start the car and keep it reving to disperse the air as there is no hand primer. note if u change the engine oil first run the car before u change fuel filter so at least the oil pressure is back to normal i hope this helps
    East Anglia
    Thanks very much, that'll give us a clue as where to start. It sounds like we're going to have to get it on our ramps to get it high enough if part of the tray has to come down.
    Pete
    Nicking Ya Dinner.
    When you drop the tray, keep it supported or it will flop and rip.
    East Anglia
    Ok cheers, I think I'll have a go at the weekend.
    Pete
    East Anglia
    I've taken a look at my car today and located the oil filter no problem, but its got what looks like a drain bolt in the middle and a massive 14? sided spanner needed to unscrew the filter cap? I think its like a cup wrench?
    Does anyone know where I can get one of these box spanner type things? We can't seem to get good enough grip with a normal oil filter strap wrench?
    I'm not sure what size it is exactly?
    Pete
    East Anglia
    Question
    Hi,
    I'm after one of these (see attachment) to undo the oil filter canister cap on my 2004 3.0 V6 CDTi.
    Does anyone know the exact side of the one I need, ie diameter and number of flutes? They are only about £5 if bought individually and I don't really want to buy a set.
    I've tried my local Vauxhall, but they say they don't sell them?
    Any help would be much appreciated.
    Pete
    dunstable
    hi all u need is a standard socket i did mine with just a normal double hex socket but i dont no what the size is u will probably find its more tha a fiver to buy if u can find the size u may be able to buy one from a motor factor i changed mine at work so i cant remember wheather i have a socket or it was from the workshop i hope this helps
  1. How to change the fuel filter on 1.9 CDTi??
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2012, 13:11
  2. vectra cdti sri fuel filter change????
    By Mads in forum Engine & Drivetrain
    Last Post: 20th March 2011, 22:50
  3. fuel filter change vec c 2.0t
    By johnturbo in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 19:36
  4. 1.9 CDTI (150) fuel filter change
    By klesniks in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2009, 13:25
  5. How to change fuel filter?
    Last Post: 31st January 2009, 14:48
fuel filter for vectra c v6
how to service a vectra c v6 cdti oil filter
vectra 3.0 diesel oil filter socket
how to change fuel filter on vectra c 3.0
how to remove oil filter vectra c v6 cdti
vectra 3.0 cdti fuel filter change
remove oil filter cap 05 vauxhall vectra
oil filter 3.0 cdti
vectra v6 fuel filter change
wheres the oil filter on 2004 vauxhall signum 3.0 diesel
oil filter vectra 30 cdti
opel vectra c 3.0cdti oil filter change
opel 3.0 cdti fuel filter
fuel filter for vauxhall signum
how to change fuel filter on vectra 3.0 cdti
vectra c 3.0 v6 cdti fuel filter
opel signum 2004 3.0 v6 cdti oil capacity
engine oil vectra 3.0 cdti
vauxhall vectra 3.0 diesel fuel filter change
vectra c fuel filter replacement
engine oil opel signum 3.0 diesel
https:www.vectra-c.comforumshowthread.php41090-Oil-and-fuel-filter-Change-on-a-CDTi-3-0-V6page2
gm vectra v6 cdti fuel filter
vectra v6 cdti fuel filter replacement
vectra v6 cdti 184 fuel filter
