Thread: will these be ok ??
    Regular Member whisky kid's Avatar
    Nov 2007
    scotland
    Default will these be ok ??
    just been to view a second hand set of oz super leggerra alloys
    shod with 225/55/17 pirelli scorpion s/t rubber will these fit my 2003 sri
    vectra have 215/45/17 at present
    member of the smoke patrol 230bhp+
    When speedometer reads 60mph (96.6km/h) actual speed will be 65.2mph (105km/h): 8.7% faster.
    thats a lot out
    the tyre stands 215 45 17 = 626mm high
    ......................225 55 17 = 680mm high
    Regular Member Ian's Avatar
    York
    shouldnt you have 215/55/17 as standard, dropping the profile to 225/45/17? I'm 99% sure they are the correct sizes, have you typoed the original size? If you have then you should be fine going from 215/55 to 225/45
    Nov 2007
    scotland
    sorry it is 215/50/17 not 215/45/17
    Regular Member Stu14t's Avatar
    Perth, Scotland
    Just changed all 4 of my tyres today from 215/50/17 to Goodyear F1 GSD3 225/45/17 today.
    Checked the speedo against the sat nav and it still reads faster than you are going, so no issues there.
    Nov 2007
    scotland
    so stu you recon on it being ok with 225/55/17 as reguards speedo
    Perth, Scotland
    I've gone down a profile but there is only a negligible difference in speed reading and mine will read even slower on the speedo. However, if you go up a profile to 55% as Chris says will make your speedo read slower than you are going and not faster like mine
    Can you do the Maths Chris?
    Regular Member corman's Avatar
    Mar 2007
    hexham
    http://www.miata.net/garage/tirecalc.html
    http://www.etyres.co.uk/tyre-size-calculator.htm
    have a look at these 2 tyre calculators, the tyres you have are'nt really a suitable size, but i suppose its up to you if you wanted to run them just watch your speeds!
    Perth, Scotland
    Quote Originally Posted by Stu14t View Post
    Thin i've even confused myself here
    Nov 2007
    scotland
    going by cormans tyre calculators i will be 3 mph out at 60 mph that should be ok [hopefully]
    will just have to watch the mrs
