Thread: Can I fit a wider tyre? 245 instead of 235
    Oct 2007
    Yorkshire
    Default Can I fit a wider tyre? 245 instead of 235
    Hi,
    I have a Vectra C with 235 35 19 tyres fitted,
    I need two new tyres and was wondering if I was able to fit 245 / 35 / 19 instead of 235 /35 / 19 at the rear.
    The car is only lowered slightly so I do not think they will rub but I wanted to check incase someone has already tried it,
    I also wonder if they will look much different to the ones on the front, I know the sidewall will be higher even though they will both be rated at 35, but do not want it to look really uneven,
    Pictures as well as suggestions will be grateful,
    Kind Regards Bren
    member of the smoke patrol 230bhp+
    yes 245 will fit
    im looking to fit 245 to 18 x 8 rims so you will be ok
    Oct 2007
    Yorkshire
    Thanks, I think they will look and handle a little better than 235, Regards Bren
    wait till you see how big they look
    Aug 2007
    Rutland
    Shouldn't rub.
    Rears would be 7mm bigger diameter and 22mm bigger circumference which is 0.5%.
    Sometimes cars can look better with a little bit of front to rear "rake" in - you are really not going to notice any difference driving though.
    Also slightly wider rubber should make it harder to kerb the wheels themselves...
    Oct 2007
    Yorkshire
    Hi, I am glad they will fit, and Cosmetically the car will look slightly meaner from the rear with wider tyres but possibly silly from the side with a higher profile which is something I need to think about,
    If Anyone has any pictures that would be great,
    I am prone to kerbing the wheels, so the extra protection will be a benefit,
    Regards Brendan
    Aug 2007
    Rutland
    I really don't think you will notice, by a casual glance, a tyre that has a higher profile of 3.5mm!
    Check this picture. The rears are LOWER profile by 3.75mm but I don't it's really ruined it... Besides which many bigger cars have different sizes front to rear.
    I'd go with it.
    Oct 2007
    Yorkshire
    Thanks, I cannot tell the difference, Regards Bren.
    I'm going tomorrow so I will ask the dealer to grab both styles and hold them side by side,
    I'll try and post photos up if I have them fitted as well,
    Regards Bren
    Regular Member Kyser143's Avatar
    Bradford
    Would be interested to see pics Bren...I might do same when mine need changing.
    Oct 2007
    Yorkshire
    Hi, They only had one style in stock for the 245 35 19 and they were very expensive so I decided to stick with the 235 35 19, They had plenty to choose from,
    Today was the first time in over a month that I have been out in the car, Its spent so much time at vauxhall, It was a dream to drive, And Problem Free,
    I'm keeping my fingers crossed that my run of bad luck with all the engine problems will now change,
    It has its M.O.T Tomorrow Morning, i've just been all over Castleford tonight trying to find a Car Wash thats open, They have all shut due to the cold weather, ******.
    i'll try and get it washed first thing
    Regards Bren
  1. Wider alloys for better braking
    By eddy931 in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2012, 20:08
  2. Tyre Help
    By Skinner in forum Suspension, Wheels & Brakes
    Last Post: 10th April 2010, 23:14
  3. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  4. Wider Car?
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2006, 09:35
