Thread: car help please
    Regular Member bish's Avatar
    peterborough cambs :P
    Default car help please
    Morning all, i brought a 04 plate 1.8 vectra c ls that had light front and light rear damage, couple of questions for ya, my air bag light is on, will this need to be tech 2, to be turned off?? and i had to replace the tailgate with a different one, and is all wired up correctly but on the dash, it is still saying its open, when its shut?? any ideas
    many thanks lloyd
    Sunny Dartmoor
    I would say yes to the tech 2 question,what i've read anyway......
    As for the tailgate,i think i remember someone else having the same problem, a switch in the mechanism,i think,needs adjusting,cant remember exactly how,do search and it should come up........
    [Ex]Admin Duncan's Avatar
    As above. Yes to the Tech 2. Had the airbags gone off? If so, you'll need to replace, and have reprogrammed, the airbag module.
    Tailgate - you just need to adjust the slam plate (the bit on the boot lip) so that it closes sufficiently without the light coming on.
    Cheers guys, will have a go at adjusting it then, no none of the air bags went off, will get some pics up, as its now back from the body shop
    Devon
    Aren't the airbag sensors just behind the front bumper so have they been damaged?
    Quote Originally Posted by signumart1 View Post
    You dont know the exact whereabouts of these do you, the damage to the front was only the bumper and dent in the front bumper bar
    cheers
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Quote Originally Posted by bish View Post
    cheers
    the crash sensors are on the side of the head lights on the front panel
    and with the air bag light still on you might have to send the airbag module of and get it re-set. as this is what i have to do its about £60 to get done
