Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Is it best to clay
    Mileage : 55000
    Default Is it best to clay
    Is it best to clay my car before I put the magiures NXT tech wax, #21 then the p21s canuba wax, or is it not neccesary?. There are slight swirls [ i wonder if the NXT will remove the swirls], Whilst i will not be looking for " show standard", I am looking to make a very good job of it,
    I hope to become as knowlageble as some of you in the car cleaning department one day.
    Thanks for any help.
    Ed
    Regular Member blr123's Avatar
    Dundee, scotland
    Hi Ed,
    I think you are going to WAX.......SEAL........WAX, you need a polish in there to help the swirls a better way is to polish, seal then wax.........wax is always the last stage.
    For swirls I think you would be better using either an All In One (AIO) cleaner/wax or a 3 step like Megs DC1, DC2 & DC3, Mothers do a 3 step aswell.
    As for claying if your car has never been clayed before then yes you should clat it but inspect the paintwork first to confirm that and check out how to use clay in the "How To" section.
    Another tip is to use the selophane wrapper from a cigarette packet, first rub your fingers over the paint.........should feel smooth then put your fingers inside and lightly rub them over the paintwork.........you'll notice the diference.
    Bryan
    Mileage : 55000
    cheers bryan
    Would it be a good idea to put some zymol on first,[ I have some left, it is what I have been useing before], Then the NXT,#21 then the p21s, Will I be wasting my time putting two types of wax on, The bonnet feels like it could do with claying,do i need to clay all of the car, or only where it feels rough,
    Thaks for your adivce.
    Ed
    Dundee, scotland
    Ed........if your car has never been clayed before then I'd suggest doing the whole car but if you think it's OK then yeah you can target the clay to areas you think need it, the only thing I'd add is that for the very best results the "PREP WORK" is the key.
    Also it's best NOT to apply #21 directly on top of a wax as it won't take very well, it is best to use a polish then #21 then wax........I would not do NXT - #21 - wax........I would polish - #21 - and finally wax.
    As a rule of thumb if you are trying to get rid of swirls then you must use at least a polish or even better a cleaner/polish first as they have cutting properties whereas wax's do not have any cutting properties they are to bring out the final sheen.
    Bryan
    PS to wax in the order you are proposing yes you would be wasting your time, best to put wax on last and couple of coats would be good.
    Mileage : 55000
    Hi I have just been reading about maguires cleaner wax, I take it I would do better to put that on first then the #21,then the p21s canuba wax. [ so the NXT and the p21s are both wax then so they both do not need to be put on at the same time.. which is the best of the two for the final coat then].
    I normaly dry the car with a very good quality chamois leather,is that a good idea?.
    Cheers once again.
    ED
    Dundee, scotland
    Quote Originally Posted by ed taylor
    Hi I have just been reading about maguires cleaner wax, I take it I would do better to put that on first then the #21 YES ,
    then the p21s canuba wax YES .
    [ so the NXT and the p21s are both wax then so they both do not need to be put on at the same time THAT IS CORRECT .
    which is the best of the two for the final coat then] P21s although you can use both one after the other i.e. 2 coats of wax .
    I normaly dry the car with a very good quality chamois leather,is that a good idea? BETTER USING A MICRO FIBER OR EVEN BETTER THE MEGS DRYING TOWEL .
    Cheers once again...........NO PROBLEM
    ED
    Bryan
    Mileage : 55000
    Cheers bryan.
    I am going in the right dirrection now.
    thanks for your help.
    Ed
    Dundee, scotland
    Ed why don't you run out and try the celophane trick..........I wish somebody would...........it's a real eye opener
    Bryan
    Mileage : 55000
    Errrm I don,t belive it I have just been out and done the celophane trick.....try it you WILL NOT belive it, I asked about claying as I thought my car,s paint was smooth, like heck is it, with the celophane it was like running my fingers over a brick....so now it will be wash dry.
    clay.
    cleaner polish.
    #21 sealer.
    NXT tech wax
    p21s canuba wax.
    Thanks to BLR [Bryan]for all you help and advice.
    Ps I would recomend to any one to try the celophane test....unbelevable.
    Ed.
    Dundee, scotland
    As Victory Meldrew would say Ed "I don't belieeeeve it"
    Bryan
  1. To clay or not to clay?
    By rob warrington in forum Detailing and Car Care Discussion
    Last Post: 28th December 2011, 19:13
  2. Gonna take you to a clay bar, clay bar CLAY BAR!!!
    By peppered in forum Detailing and Car Care Discussion
    Last Post: 7th September 2009, 21:11
  3. Clay - WOW!!
    By davree in forum Detailing and Car Care Discussion
    Last Post: 16th March 2009, 14:24
  4. Clay Day
    By T4M in forum Quick Photo Album
    Last Post: 6th May 2008, 19:15
  5. What Clay??
    By DeathStar in forum Detailing and Car Care Discussion
    Last Post: 27th January 2008, 23:58
