Thread: cruise control
    Regular Member VEC-MAN's Avatar
    Nov 2007
    LEICESTERSHIRE
    Default cruise control
    hi all, been down london for the day, used the c.c on the way down no problem.was fine on the journey home until i stopped for fuel. gets upto speed and the c.c wpuld not turn on.
    any ideas!!!!
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Have you checked the spring behind the clutch sometimes get stuck as this will stop cc from working?
    Regular Member Stu14t's Avatar
    Perth, Scotland
    I've done this also and it may be what you did.
    I think you have to press the break pedal to activate the system when you start up and drive off. If you just move off onto a motorway you may not have to press the break.
    Just a thought.
    Regular Member ion's Avatar
    walsall
    Yep, you do have to press the brake to activate it.
    If you started up & pulled away without doing so it definitely will not work.
    After you touch the brake at any time it should then work again.
    Nov 2007
    LEICESTERSHIRE
    Quote Originally Posted by ion View Post
    hi guys , yes that does make sense , i did pull away to re join the m.w,
    did nit touch the brake for miles ,did`nt try again after that.
    thank you.
    Aug 2007
    Rutland
    Often catches me out too, just a quick tap on th epedal and all is fine.
    Aug 2007
    Rutland
    Or I suppose yours could be broken!
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    could be a switch on the clutch pedal or the brake pedal
    Mileage : 000
    Nice to meet up with you pete. I bet you though who is this "loony" following me......... mind you my sat nav was no better either.
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
