Results 1 to 10 of 11
Thread: CD 50 Aux in
    Regular Member kantimpalo's Avatar
    Feb 2007
    Spain
    Default CD 50 Aux in
    Anyone knows if is possible to have Aux-IN in CD50 Phone Radio?
    Look the photo...
    Feb 2007
    Spain
    Up¡¡
    Feb 2006
    Dorset
    Yes , its got it written on the top , bottom right hand block on the quadlock on the back of the unit , aux L (left) aux R (right) and Aux G (ground) might need enabling on the unit though.
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    It does look as if there are AUX L and AUX R pins (along with the AUX GND pin) in the lower left block shown so maybe it will be possible to use them for an input from an MP3 player.
    The aux-in on the other units I've seen have been mono for use with phone kits (with two pins) so the three pins here would indicate a stereo input.
    Have a go and see what happens!
    Feb 2006
    Dorset
    Thats an Aux input , external in (mono for phone kits) is labled as PH+ and PH- on the rear of the units
    Jun 2006
    Somewhere...
    Quote Originally Posted by DennisTheMenace View Post
    You're correct, I did mean inputs in general and miss-used aux-in.
    Feb 2007
    Spain
    Last Monday, in the Opel dealer, we have tried enable the AUX_IN on the CD50, using the Tech2, but this aren't possible.
    We have tried changing the CD50 radio code (13) to (12) (Zafira code) but the Unit no accept this change.
    Anyone knows other procedure?
    I'm sorry for my little English. I'm learning your language. Thanks for your help.
    Feb 2006
    Dorset
    Is there a hidden menu on the unit to switch aux on ? try connecting up to the aux in , it might switch its self on once it sees something going in on those inputs
    Regular Member Gordon B's Avatar
    Jan 2008
    Washington
    Anyone know if my CD70 has aux in, and does it take a handsfree interupt so that the phone comes through the main speakers?
    Feb 2006
    Dorset
    yes it has direct audio input for hands free , the pins are labled on the back of the unit PH + and - and the mute is in the main power block ,
cd50 phone aux in
cd 50 phone aux
aux input vectra c cd50
radio cd50 aux
aux in cd 50 phone
cd 50 phone aux in
aux cd 50 phone
Opel CD50 aux connector
cd 50 opel aux
Aux на CD50 phone
aux cd50 phone
vauxhall cd50 aux
cd 50 phone aux english
vectra c cd 50 phone aux
https:www.vectra-c.comforumshowthread.php40941-CD-50-Aux-in
activatw aux on cd50
using mp3 input on cd50
cd50 phone aux
