Results 1 to 10 of 11
Thread: Auto dimming wing mirror info request!!!!!
    Sunny Dartmoor
    Default Auto dimming wing mirror info request!!!!!
    Following on from this thread...
    http://www.vectra-c.com/forum/showthread.php?t=40915
    Was wondering if anyone knew if this is possible to retro-fit it and info on how its done,cheers......
    [Ex]Admin Duncan's Avatar
    Your mirror housing will need to have the relevant wiring for starters. It may already be in the loom going into it - not sure. You'll need to pop off your glass to see if you have spare wires. I think you also need the 'Upper' spec of DDM (Drivers Door Module). You also need, I'd think, to have the inside dimming mirror as that has the sensor on it that controls whether/when it dims.
    Regular Member Ian's Avatar
    York
    Could you get the same mirror but for a left hand drive one, and then have both doing it?
    Sunny Dartmoor
    Thanks Duncan,I have the inside dimming mirror,retro-fitted that last month,so will see if my wing mirror has the extra wires,anyone know what or how many wires i should be looking for.........
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    I very much doubt the wires will be there if you had to wire up the auto dim one yourself, but you never know with VX...
    Quote Originally Posted by Ian View Post
    No, only the DDM can be programmed to make the glass dim.
    Regular Member Bucko's Avatar
    Pudsey
    On the back of the auto dimming wing mirror glass is an extra 2 pin plug on the other end to the two connectors for the heating element. Also the mirror looks more orangy/yellow than a normal mirror. Got a replacement and this is what was supplied. When I connected the wires to the plug (thought it was a mod by Vx) noticed the mirror went darker whan I switched the heated bit on.
    Sunny Dartmoor
    So you're saying its just a case of buying a new mirror,whats the part no.???
    Pudsey
    part number on the box is 24461569.
    but if you don't have the extra wires in your mirror housing and the DDM then I think it probably won't work, but who knows??
    Sunny Dartmoor
    Thanks for that Bucko....
  1. Auto wipers.. and auto dimming mirror ?
    Last Post: 28th January 2009, 01:24
  2. Auto Dimming Mirror/Auto Wipers
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 21:42
  3. Auto dimming Wing Mirror or Mirrors?
    By Craig Rogers in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2008, 12:30
  4. Pic request - retro fit auto dimming mirror
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2008, 14:40
vectra c auto dimming wing mirror
vauxhall vectra c dimming wing mirror
vauxhall insignia wing mirror auto dim
vectra c auto dim wing mirror just driver side
vectra c auto dim wing mirror how 2
