Results 1 to 10 of 14
Thread: dump valve?
    Regular Member wingers1982's Avatar
    barnsley
    Default dump valve?
    my friends keep saying put a dump valve on my car and i do i like the sound of them ( i had one on my impreza wrx i use to own ) do they work on diesels? help im confused my brain hurts
    Regular Member Craig1985's Avatar
    harwich essex
    id like 1 too? dnt know if they wrk? duncan will know or spoons?
    barnsley
    yeah it works just dont know if it'll screw something up
    Regular Member Signum_CDTI's Avatar
    May 2007
    Somewhere and Nowhere....
    someone I knew put one on a Focu TDCi - sounded like an HGV lettin off its airbrakes - pressure was really high
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Its electronically controlled. I fancied one then couldnt be arsed with wiring up and the extra parts
    You can fit a dump valve to diesels but there isn't really that much point. As Diesels have no throttle valve (Inlet direct to cylinders) you won't get the closed throttle pressure build up of a Petrol Turbo and therefore no gains/advantage.
    To use a dump valve on a diesel involves wiring in a microswitch, usually to the throttle pedal, to activate the solenoid to open the dump valve (to dump the excess boost).
    They don't give any more bhp or torque, but they can, if adjusted correctly, quicken the spool up (slightly) of the turbo through the gears.
    Search for 'dump valve diesel' to bring up a few threads. Nutron fitted one. Not sure what it did for him, or whether he's got it on his current car - you'd need to read through the threads. I think others may have fitted them too.
    On a diesel, it seems a lot of faff for no real benefit from what I remember.
    The other ones you can fit are the electronic ones that simply make an electronically generated sound, activated by a microswitch on the throttle pedal, to make the noise of a dump valve. Very, very naff indeed.
    EVERYWHERE
    Can you get them that make your engine sound like a Ferrari V12 as well? LOL
    The other alternative is of course is to sell the Vectra and buy an 'Impreza'.They're jolly good fun,but gutless as hell and love petrol stations.
    barnsley
    i had the impreza wrx import running 330bhp at the wheels it wasnt gutless at all it scared me to death but i agree loved the petrol stations loved the sound to death use to make people jump and heads spin very good fun
    EVERYWHERE
    Quote Originally Posted by wingers1982 View Post
    "Gutless" in the way that unless you had 4,000 rpm on the rev counter nothing really much happened when you hit the gas.There has to be some trade off for all that top end poke I guess.Great fun when you're in the mood,irritating as hell when you're not.
    member of the smoke patrol 230bhp+
    it will i know it does and im not saying a word but no switches needed and how to is it part of a bigger ongoing plan it's all hush hush and i dont know anything about it anyway but here is a littel tester for you all to see
    [IMG][/IMG]
    im i good or what
    and where is this going ,,,,,,,down there to the intercooler
    [IMG][/IMG]
    and this isnt the finished job ,, it gets so much better much better you will all have to wait and see whats it all about on the 24th of feb
  1. 2.0 DTI dump valve ??
    By christianrickhuss in forum Diesel Engine related
    Last Post: 26th April 2013, 17:55
  2. Dump valve
    By irmscher-brett in forum Diesel Engine related
    Last Post: 24th December 2010, 14:45
  3. Replies: 23
    Last Post: 6th March 2009, 09:00
  4. Which Dump Valve
    By rob888 in forum Petrol Engine related
    Last Post: 23rd January 2008, 14:14
