Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: still vibrating my way round gt yarmouth
    Regular Member madmark's Avatar
    great yarmouth
    Eek still vibrating my way round gt yarmouth
    put my veccy in another garage today same result cannot pinpoint the fault now 5 garages including main dealers what ssss wwwrrrrooonngg with my veccy 2ltr td vectra clud 03 plate drives fine slow speeds vibrates once you accelorate above 45mph only happens when u accelorate or labour the car feels like the wheel falling off put clutch in and let it free roll at all speeds its fine untill u accelorate again its a shackyyyyy model had wheels changed stearing checked and rest of the car checked no fault foundwhat should i change first got to start replacing parts to aliminate them please help any1 got a ns driveshaft complete for a 03 vectra club 2 ltr td
    Clutch/flywheel...?
    great yarmouth
    Quote Originally Posted by Penfold101 View Post
    Clutch/flywheel...?
    sounds alot of money to find out if its that as no one can find the fault dont realy want to gamble loads of cash in to it unless its a def cure
    derby
    i know this is along shot but could be the bearings on the drive shaft reason i know is when i took my peugeot apart i lost about 3 little rolers so i just greased it up shoved it back in and it made a grinding rumbling noise but this is only a suggestion
    you could have partially seized offside front driveshaft support bearing..or you could have a flywheel problem..
    the fact it only does it under load and at a certain rotating speed does make me think it's either of those two..check the support bearing for freeplay ( side float) and does it turn smoothly..the flywheel thou is a bigger job.. gearbox off.. but it will also let you inspect the clutch at the same time..
    Thornton Dale
    Vehicle : Transit Custom
    Trim : Limited
    Engine : 125PS
    I had the same problem with my Vectra SRi 2.2 52 plate and it took me ages to work out the problem.
    I would bet money its the dualmass flywheel unfortunately.
    You DO NOT need to replace the clutch at the same time if its OK, mine has almost 60k miles and I left the clutch in and just replaced the flywheel, £350 ish as I remember with discount from Vauxhall.
    Remove both driveshafts, drop subframe completely, remove gearbox completely, clutch off and there the ***** is.
    great yarmouth
    thanx every1 for ur replys latest update this may b a very long shot me and my mate was driving about treing to pinpoint weather it was from the ns or os the most we both said ns so i changed ns front alloy to the spare wheel witch is smaller in width ? this made the vibration reduce by loads but not go away ? my thought is as the wheel was smaller it dident vibrate so much i thinking the vibration is more ns drivetrain does this make sence to anybody else or am i going shaking mad lol veccy booked in tuesday for new ns driveshaft complete did check it and there is a little play in joints but not major fingers crossed will keep u all up to date once again thankyou every1 i will get there in the end and let you all know the cause
    Regular Member Silver V's Avatar
    Jul 2006
    mmmmmmmmmmmm
    sounds like a drive shaft. my ford connect did this, especially up hills!! and like you say put clutch in and was fine, but seeing as main dealer didnt spot it, it doesnt fill me with alot of hope. reading the posts above i cant see it being anything other than the flywheel or drive train.
    great yarmouth
    will do this driveshaft and finger crossed if it aint that will get some prices for flywheel replacement will keep u all up to date thanx all
    great yarmouth
    Default update
    the garage that took veccy to do the driveshaft ordered the wrong driveshaft so it dident get done in the end they then told me to take it away they dont want to know so still got no news yet its now booked in to another garage monday for a check seems like no1 wants to work on it will update again monday knight once yet another garage looked at it thanx mark
  1. Black pre-face BW02 *** Great Yarmouth
    By the_wave_rider in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 25th May 2011, 10:14
  2. Yarmouth wax museum
    By pubcarking in forum The 'Off Topic' room
    Last Post: 15th April 2010, 11:14
  3. Black vectra L33 *** in Great Yarmouth 25/02/10
    Last Post: 25th February 2010, 20:35
  4. Black SRI 57 reg Grt Yarmouth (Tesco)
    Last Post: 29th January 2010, 21:39
  5. Spotted ST07 silver VXR in Great Yarmouth
    Last Post: 24th January 2010, 17:59
vectra c drive shaft support bearing
vectra vibrating 45mph
