Thread: gear box oil
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    Default gear box oil
    if just been on the opie oils website through the forum for a discount price and it says the gear box takes 4ltrs is that right or is that the amount it comes as i have about 2ltrs of ep 80 is this correct
    thanks for your help peeps
    scotland
    cant be 100% positive but 4 ltr seems too much , an average engine takes that ! your probably more near it with 2 ltr.
    I recently topped up after replacing a driveshaft and it took less than a litre to replace what i lost .
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Quote Originally Posted by glynn View Post
    3.2 Ltrs for the 6 speed F40 box, I changed mine about a month back.
    Dean
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    Lad's can I ask why you felt you needed to change the gearbox oil?
    Quote Originally Posted by Stevie-B View Post
    i needed gear box oil as i had to change my gearbox as i brought my car from a salvage auction
    Regular Member VXR CDTi's Avatar
    Jan 2008
    South Wales
    How do u change the gear box oil coz i think i need to do mine, what oil should i use?
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Mines an auto box, does the oil need changing?
    Thanks in advance
    Nov 2007
    Staffordshire
    I changed mine to try & better the V cold tight shifting & the F40 6 Speeder Crunch into 2nd.
    I used Redline MTL & it did make things better
    As for changing, It's a bit awkward, Drain plug on lower side of gearbox casing, Level plug higher up, & filler plug very awkwardly located V near & under the battery Box.
    Make sure you can remove the filler plug before you drain Ther is nothing worse than having shiny new oil to go in, The old oil sat in the drain tray & a disabled car !!!!
    Dean
    wales
    Quote Originally Posted by Davidjs68 View Post
    Thanks in advance
    auto box oil should be changed around 40K in the service handbook on my 2002 2.2 SRI had my done at main dealer last year £80 iirc
    HTH
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2016, 16:15
  2. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
