Results 1 to 10 of 24
Thread: coolant light on
    Regular Member moles-sri's Avatar
    Jan 2008
    south wales
    Default coolant light on
    hey guys my coolent light came on tonight on the way home from work but the level seems fine what else could cause this light to come on?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by moles-sri View Post
    If you look closely, it has dropped and this is 90% of the time jammed open thermostat. Nothing serious, just means the engine takes longer to heat up and usually runs 3degrees under normal.
    The slightly low level is because the thermostat has jammed open and water is going through the radiator instead of circulating/returning to the reservior, hence low level, just top it up with a drop of water or coolant if you have some handy.
    I had this problem too and thermostat still no fixed yet!!!
    Gazza4
    Jan 2008
    south wales
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    cheers gazza4, will top it up in the morning,
    so i wont need to replace the thermostat and it wont cause any other problems?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Try and get it replaced, it really isn't healthy to have an 'overcooled' engine.
    If you drive on frosty mornings you will notice it LOL
    Also follow the manual as for the ideal level.
    Gazza4
    Jan 2008
    south wales
    Gazza4
    bit of problem ther i have no manual? lol werent one in the car wen i bought it think previous owner sold it on ebay ha ha
    Huh? The cooling system is a closed circuit. Whether the thermostat is faulty or not, at some point it's going to be open, and as the radiator is full when coolant from the engine passes through it, the return feed from the radiator is going to pass the coolant back into the header tank/engine.
    From what you're saying, if the thermostat were operating correctly, as soon as the engine got warm and the stat opened, the low level light would always come on.
    Goto Vauxhall's website, sign up for "My Vauxhall" and download a free handbook in pdf format for your car.
    Jan 2008
    south wales
    cheers dave, ne ideas y the light is on then
    south wales
    mines done it a few times just topped it up to the line then its fine not come on for months now i hope mine is ok
    simple answers first.....if the level is fine and the light is on, it's a faulty sender.....located in the bottle...replace either the sender or the complete header tank..
    As big dave said.. sealed system.. operation of thermostat will have no effect on the level whatsoever..
  1. coolant light help.
    By frasedeb in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd February 2011, 21:46
  2. Coolant Light
    By kevrod79 in forum Engine & Drivetrain
    Last Post: 19th November 2010, 10:56
  3. coolant light
    By iam2103 in forum Engine & Drivetrain
    Last Post: 19th July 2010, 10:35
  4. low coolant warning light
    By wxmlad in forum Electrical & ICE (including SatNav)
    Last Post: 16th August 2006, 06:29
  5. Coolant Light
    By bruceybonus in forum Engine & Drivetrain
    Last Post: 17th November 2005, 06:25
astra j type coolant light on
just put new thermostat in my vectra c and now radiator light on
