Thread: Head unit cage
    Wetherby
    Default Head unit cage
    It's been one of those days, but when I got home I found that Mr Post Man had delivered my new head unit and associated bits
    So, after ripping out my old CD30 I am a bit stuck now.... How on earth do you get the old cage out? I've taken out the screw at the back and it's far too dark and cold now to work out.
    Please... help!!
    Regular Member kns's Avatar
    Northampton
    you just have to prize it out, you will find the cage very stiff but it will come out. make sure the lugs just inside the cage are not bent in behind the trim.
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    to be honest i left mine in when i put in a single din! it made the fit of the fascia and the radio alot better.
    Feb 2006
    Dorset
    bend it in top and bottom a little and it should just slide out .
    Wetherby
    It came out with a good pull and everything is installed and working nicely
  1. New head unit
    By blackbeauty in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2011, 17:16
  2. Help fitting double din head unit... aftermarket cage question?
    By Deann in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2011, 10:23
  3. head unit
    By brant2474 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2009, 12:12
  4. CD Head Unit
    By craig-k in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2009, 22:00
  5. Which head unit ?
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2007, 19:38
