Thread: How To Change Spark Plugs On 3.2 V6
    Regular Member tommyk999's Avatar
    May 2007
    Oxford
    Default How To Change Spark Plugs On 3.2 V6
    Hi,
    can anyone help me? I need change the spark plugs and i need a guide how to do it and what for tools i would need.
    Nicking Ya Dinner.
    PM Mark GSi, he's the right person to go through it.
    Jul 2006
    Mexico
    Check this thread out....will give you a clue
    http://forum.vectra-c.com/showthread...hlight=insides
    in a nutshell.. you'll need to remove the intake hose from the butterfly assy.. remove the butterfly assy from the plenubm to expose one of the mounting screws..the other 5 are under the plastic 'ecotec' cover which snaps up and off..use a VERY long torx bit to remove 6 little setscrews..ther are tight as they normally corrode into the alloy inlet manifold...
    get an assistant to hold the plenubm up about 8" while you work underneath it saving disconnecting all the hoses.....then you can access the coilpacks and the plugs underneath them.. allow an hour if you don't chew the heads of the stupid 6 soft retaining screws....
    tools are a very long extension torx drive, ratchet, long extension bar with the slimline style plug tool and some torx sockets..
    Mileage : 000
    What size is the Torx head/socket Mark? Please.
    What lenght are the Torx bolts and what is the thread size Too, as I would think of replacing them if posible, Mark.
    Nicking Ya Dinner.
    Quote Originally Posted by ed taylor View Post
    Only do them if they seem to need doing Ed, I did mine on the Omega and the difference before and after was absolutely nothing.
    May 2007
    Oxford
    there was a pdf file on forum with all the photos and step by step guide as well, do anybody got a clue where can i find it???
    May 2007
    Oxford
  1. How often do you change the spark plugs???
    By philgst in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2011, 12:36
  2. Spark Plugs - when to change?
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2007, 18:14
  3. How on earth do you change the spark plugs on the 3.2 ???
    By muffking in forum Engine & Drivetrain
    Last Post: 17th February 2007, 15:06
vectra 3.2 v6 spark plug change
holden vectra zc 3.2 spark plug replacement
fitting vauxhall vectra 3.2 v6 spark plugs
how to change spark plugs on vectra 3.2 v6
spark plug change vectra v6
how to change spark plugs in vectra 3.2
vectra spark plugs change
how to remove head plugs vectra zc 3.2
how to change spark plugs vectra 3.2
plug change ecotec v6
location of spark plugs on a vectra engine 3.2 v6
https:www.vectra-c.comforumshowthread.php40763-How-To-Change-Spark-Plugs-On-3-2-V6
Change vectra gsi spark plugs
how to replace spark plugs on vectra
how to change spark plugs v6 signum www.vectra-c.com
how to changespark plugs on 3.2 signum
