Thread: front fogs misting
    Regular Member PeteRs's Avatar
    here or there
    Default front fogs misting
    hi my front fogs are misting up is this common fault that can be sorted easily or do i have to live with it or buy new thanks
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    It is a common pain in the a$$. Either put a small pack of silica gel ( like the ones you get in a shoe box) in the bottom then put the cover back on, or take the cover off and dry the inside of the lens with a hairdryer. Good luck
    3.2 v6 Signum and loving it
    here or there
    ok i'll hairdryer 1st thanks
    mine were doing that, I left the cap off for a few days while it was dry, put them back on, been fine ever since
    here or there
    is the cover easy to get to nothing silly like taking bumper off
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Dead easy hand up behind fog twist and remove cover, hairdryer and probably best to put the silica gel in as well.
    here or there
    ok im off outside to sort them thanks
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    or you can put news paper over the light unit and put the fogs on. the heat generated from the bulb will dry it
    Quote Originally Posted by glynn View Post
    and if it gets hot enough you could cook on the flames! The lamp gets hot enough on its own to dry them out
  1. front fogs
    By MID LIFE CRISIS in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2011, 19:39
  2. Front fogs
    By bigmac in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2010, 00:20
  3. front fogs
    By cbl1985 in forum Electrical & ICE (including SatNav)
    Last Post: 5th February 2010, 19:10
  4. Front Fogs
    By parapaul in forum Styling
    Last Post: 18th July 2006, 22:16
