Results 1 to 10 of 13
Thread: Dumb Question? Change wheels, reprog speedo
    Regular Member Leviathan's Avatar
    Middlesbrough, Cleveland
    Default Dumb Question? Change wheels, reprog speedo
    According to the Vectra hand book. If you change the factory fitted wheels and tyres to a different size then you should consult Vx to see if the electronics should be altered to show corrct speed on the speedo.
    How realistic is this, anyone enquired? It makes a bit of sense I suppose but woldnt have thought to check with them.
    member of the smoke patrol 230bhp+
    have a look here for all the info you will need
    http://www.rims-n-tires.com/rt_specs.jsp?postId=906
    Quote Originally Posted by chrisgettings View Post
    Whoa! Cheers, so really, even if you just go 1" bigger you should get the speedo reprogrammed in some cases. Scary, how many people will be going even justa few mph faster than they think.
    cambs
    Quote Originally Posted by Leviathan View Post
    no need to get speedo done
    the chart will show you your original wheel hight
    pick the rims you want and match the wheel hight
    mine had 215/55/16 but changed them to 215/50/17 or 225/45/17
    the wheel hight is about the same so no need to get speedo adjusted.
    hard to explain but if you get correct tyres fo the wheels you will not need to adjust speedo which will be a bit pricey i think.
    Quote Originally Posted by mhvcbv View Post
    hard to explain but if you get correct tyres fo the wheels you will not need to adjust speedo.
    In laymans terms, if you fit a larger diameter wheel with lower profile tyre, then as long as the overall diameter of both the wheel & tyre is still the same as before, then the speedo will read the same.
    Whatever a Tech2 costs to perform.
    [Ex]Admin Duncan's Avatar
    As long as you're within a couple of % of the original wheel diameter then no real need for the Tech 2.
    Chester
    Using the Tom Tom as a guide 70 MPH indicated on the Speedo was around 66 MPH on the Tom Tom with my 16" steelies.
    70 MPH indicated on the Speedo is now 68 MPH on the Tom Tom with my 17" alloys.
    Cheers y'all, I get it now.
    Melbourne, Australia
    It only takes a minute or two with a Tech 2, so it depends how much you dealer feels like getting stuck into you...
    So - If I have 16" steels on and I swap them for 16" alloys, I can put my existing tyres on and there is no difference?
    Thanks everyone
  1. Change of wheels - calibrate speedo?
    By cossie in forum Suspension, Wheels & Brakes
    Last Post: 5th April 2012, 17:22
  2. Dumb question....
    By martyngell in forum Y & Z30DT Specific
    Last Post: 2nd March 2012, 15:57
  3. may be a dumb question but....
    By steve.s in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd August 2009, 16:44
  4. Dumb Question
    By Bethan39 in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2009, 17:02
  5. A Dumb Question
    By shan in forum General Chat
    Last Post: 25th October 2007, 23:18
