Results 1 to 10 of 26
Thread: What Temperature does Your Cdti Run at ??
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Default What Temperature does Your Cdti Run at ??
    HellOo.
    Weather has warmed up somewhat over the past couple of days (Far to Gorgeous for work )
    Now my coolant temp never really ever got above 80 & dropped on tickover, But today it reached 85 - 87. I have never seen it go that high, But !! I have only ever ownded the Car through Winter !! So what is the Normalish running temp through Spring Summer Etc ??
    Dean
    Nicking Ya Dinner.
    Should just point to 12 o'clock on the gauge iirc.
    Regular Member LJ sxi-nav's Avatar
    Winchester
    85-87 sounds right and it's idenical to mine, mine might creep to 90 if sat in traffic, but on a run always 85-87. usually about the same all year iirc
    May 2007
    West Yorkshire
    points to about ten o'clock
    Regular Member Karl's Avatar
    Sunderland
    85ish
    Nov 2007
    Staffordshire
    Cheers chaps.
    12 Oclock being 90 then, I suppose when you look at the spacings on the Gauge, 90 is Halfway & most modern cars seem to sit at that on their gauges & not move, I have noticed with Diesels though that they do tend to fluctuate far more than the Petrol equivalent !!.
    Dean
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    never seen mine at 90!! 85 seems about right but can run cooler in very cold weather
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    85 for me too.
    Full Member Big Sig's Avatar
    85-90. Never more than that, just let it tick over until the fan comes on to check its working and note the gauge temps. All cars will vary a little.
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    and again 85 for me
  1. CDTi 150 Running Temperature
    By tony-1977 in forum Engine & Drivetrain
    Last Post: 28th March 2012, 11:38
  2. V6 CDTI temperature
    By BigWilko in forum Y & Z30DT Specific
    Last Post: 6th December 2011, 15:05
  3. Temperature Guage - 05 CDTi 150
    By Gallen in forum Engine & Drivetrain
    Last Post: 15th November 2010, 12:28
  4. 3.0 CDTi Y30DT engine oil temperature
    By Celes in forum Engine & Drivetrain
    Last Post: 16th July 2009, 22:48
  5. CDTI Engine temperature ?
    By dinac_cro in forum Engine & Drivetrain
    Last Post: 26th December 2007, 18:15
