Thread: Exhaust heat shields
    Jan 2006
    Skynet HQ EMEC#5
    Default Exhaust heat shields
    I have noticed that the exhaust heat shield above the rear silencer has come loose, flapping about.
    The shield has worn around the nuts / washers, allowing it to drop.
    Normally I would just put a bigger washer on to hold it in position.
    The problem I have is that the studs are broken off where they fix to the spare wheel well.
    Does anyone have any suggestions how to fix this back in position?
    There must be others that have had bother with this?
    member of the smoke patrol 230bhp+
    dyamat will work as a heat shield
    but remember its only dynamat extreme that can be used
    Regular Member Mick B's Avatar
    North East
    I have just replaced one and came across the same issues with rusty studs.All I did was use a few small self tappers to hold it in place.Drill a small pilot hole and then tighten it up.Make sure to use a bit of copper grease to seal the newly drilled holes.Also make sure nothing is behind the area you are going to drill through.
    [Ex]Admin Duncan's Avatar
    Noticed the same on one of mine (the hole in the shield worn allowing it to drop past the nut). The nut was able to come off so was able to get a larger washer on. While I was there I was going to stick a washer on the other side that looked like it was not too far away from doing the same, but the nut was seized solid and I would've snapped it off if I'd tried to undo it, so I left it. If the shield hole wears on that side, and the shield becomes loose, then I'll do the same as Mick said and pop in a self-tapper.
  1. Duel exhaust - where to get a right hand exhaust heat shield
    By Innes in forum Bodywork & Interior
    Last Post: 29th November 2011, 00:47
  2. exhaust condition and heat shield
    By pix in forum Vectra C / Signum Troubleshooting
    Last Post: 24th June 2011, 20:31
  3. AIR FILTER HEAT SHIELDS 2.2 sri
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2009, 20:54
  4. Dual Exit Exhaust Heat Sheild
    By kev bux in forum Engine & Drivetrain
    Last Post: 30th June 2008, 21:56
vectra exhaust heat shield repair
vauxhall vectra c exhaust heat shield
vectraheatshield
what size nut holds on exhaust heat shield vectra c
vectra c heat shield
zafira b exhaust heat shield
vauxhall vectra c heat shield new
Vauxhall vectra b exhaust heat shield
