Thread: CDC40 info?? DAB/Subwoofer??
    Gwent
    Default CDC40 info?? DAB/Subwoofer??
    Hi, not strictly Vectra-c, but just wondering if anyone has any insight/info into the CDC40 unit??
    I ordered a Zafira B SRi CDTi 150, with CDC40 + DAB, I read from the literature that the CDC40 came with a 7 speaker set up.. great I thought, DAB, 7 speakers must mean a sub!!!
    When it went to build, VX changed the specs for the SRI, and it seems all the 150 CDTi's to not allow DAB, and on delivery of the car, I can only see 6 speakers, with no 'subwoofer' option appearing under the sound settings.. which is shown as an option in the Audio manual..
    Does anyone know anything about the new infotainment systems, can a sub be added after, how would the unit then know about it? is it software, or configured when a 'sub' amp unit is plugged into it??
    The sound isn't bad, I can live without DAB, but a sub would be nice, especially if integrated properly into the siund options, as it has speed sensitive bass management, which would be handy..
    In fact any info at all on the whole new infotainment systems, such as how they go together as a system, are all changes made via software, or auto-discovery of plugged in units?? and why can't some models have DAB?
    cheers
    Phil
    [Ex]Admin Duncan's Avatar
    If the Zaf is the same as the Vec C, the seventh speaker isn't a sub - it's a centre speaker under the grille on the dash - just in front of the windscreen. This may be where your 'missing' seventh speaker is?
    Some models of Vec C and Signum have nine speakers as they have an extra tweeter in the rear doors.
    HTH
    Gwent
    Cheers, I'll check...
    I've just been hunting on VX's website, and it seems there specifications for the CDC40 are different to the latest brochure.. I'm not that bothered, it sounds half decent, shame it doesn't do MP3's.. I can always add a sub myself, just curious as to see if anyone has the subwoofer settings on their CDC40 in their Veccie.. and if it made a difference?
    Regular Member Tim2100's Avatar
    Walsall
    No RCA Preouts on the standard VX stereos inc. the CD70
    So to add a sub you will need to either take a lead from the rear speakers or change the stereo
    Feb 2006
    Dorset
    Sorry to drag up an old post but....The DAB unit does have mono output for subwoofer on the rear of the unit in one of the lower pins of the quadlock marked up sw+ sw-, it may need to be activated by the dealer though . im ordering my car on the 21st next time im up at the office so i will find out more about the car when its in my grubby mits , also want to try and intergrate my ipod , without using an fm adaptor .
    Gwent
    On the Zaf SRI CDTi, in fact it seems all cars with ESP, the DAB is not supplied with the CDC40.. no idea why.. but is the SW +/- likely to be there if there is no DAB?
    How did you find out the info??
    I suppose I could just take the unit out and have a look? Is it just 4 hex bolts holding the CDC unit in??? how easy is it to take out??? anyone know??? do you need to enter a code when putting it back??
    cheers
    Phil
    Feb 2006
    Dorset
    Im a mobile comms engineer , so im ripping cars apart all the time fitting kit to them .
    The later radios i dont think have the grub screws anymore , you can get the large din keys from halfords , these are the ones you need .
    http://www.addacdchanger.co.uk/Acces...o_Removal_Tool
    Mileage : 000
    I know my vectra has 9 speakers, well so the brochure says, I have wondered where the 9th speaker was, I in my ignorance thought there was a bass speaker somewhere, as the bass is very good, I would not have thought it was in the dashboard grill!!, but there you go you learn spmething every day. Cheers Duncan.
    Regular Member Trel's Avatar
    Felixstowe Suffolk
    9 speakers...no sub, so had 2 subs fitted. Now real bass.
  1. JBL Subwoofer + CDC40
    By Mark-R in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2012, 00:34
  2. CDC40 to CDC40 MP3 upgrade.... any advice?
    By eamond in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2012, 08:02
  3. Subwoofer Box
    By jrwilshire2003 in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2010, 00:16
  4. Couldn't enable subwoofer on cdc40
    By Mania in forum Electrical & ICE (including SatNav)
    Last Post: 10th November 2008, 20:28
  5. subwoofer
    By fenderguitar in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2007, 17:27
